-   -   Transfer Case Leak Help (http://www.jeepforum.com/forum/f12/transfer-case-leak-help-1239654/)
95_Sahara 07-14-2011 02:08 PM
Is this just the Pinion Seal that needs to be replaced? Also I'm taking a 7hr round trip this weekend...should I be ok?
https://fbcdn-sphotos-a.akamaihd.net..._7035060_n.jpg
jeepbluexj 07-14-2011 02:11 PM
looks like the seal went happen to mine before and i drove from jersey to ohio with it leaking i was fine just top off the fluid and check it when u get to where your going
mrdeath2000 07-14-2011 03:11 PM
DEAR LORD!!! Did you pull that driveshaft from the bottom of the ocean???
pickup a seal and a bushing for the TC. I read in other articles they can be a PITA to remove/install, but if you have another vehicle, once you get it off, take it to a local trans shop and they can R&R the seals/bushings for free or <$20.
Just make sure when you get your seal and pull the slip yoke out, feel the yoke and make sure its smooth and not have any burrs that will tear up your new seal. then make sure the seal is the right size on the yoke and not too big.
Mean Max 07-14-2011 03:43 PM
Exactly what I was thinking.
Personally, I'd let it go. Just keep the fluid topped up in the case.
Think of it as an asset, not a liability. Instead of thinking "leak" (bad) think "proactive rust control system" (good) instead.
Seriously, it's not as bad as it looks. Do the repair as mrdeath2000 suggested, but it can wait until you're ready.
Max
g4x4xgeoff 07-14-2011 03:45 PM
that's vermont rust for you!
my jeep was from vermont...looked just like that. 90% new metal, and it's somewhat better....somewhat....
mazyj 07-14-2011 03:46 PM
I agree with Mean Max. Mine has looked like that for years and I just check the fluid every once in a while. As well as rust control it also ensures the fluid is always fresh!
Mean Max 07-14-2011 03:47 PM
See? You can win TWICE!
Max
95_Sahara 07-14-2011 04:36 PM
Hell Yeah! Vermont Rust..The Rest of it doesn't look like that, frame and body are in great shape. lol..So had to drive to Sears and pick up a 30mm (only friken socket I don't own) and picked up fluid to only find the fluid level is fine....Guess I will just keep an eye on the level. Time to return the fluid.
https://fbcdn-sphotos-a.akamaihd.net..._3275952_n.jpg
The time now is 02:28 AM.
