Transfer-case Leak - JeepForum.com
post #1 of 9 Old 11-17-2008, 04:31 PM Thread Starter
JeepYJ187
Transfer-case Leak
I have a small leak that seems to drip out the little red seal around the output shaft. i have bought the new seal but i dont see how to replace it, ohh btw i have a np231 xfer case.
JeepYJ187 is offline
post #2 of 9 Old 11-17-2008, 04:35 PM
aaronc88
output to rear drive shaft or Front drive shaft?
My work
aaronc88 is offline
post #3 of 9 Old 11-17-2008, 04:40 PM Thread Starter
JeepYJ187
ohh its the output to the rear.
post #4 of 9 Old 11-17-2008, 05:02 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
5 minute job.
1) Pull the driveshaft.
2) Pry the seal out with a seal puller, or a flat screwdriver.
3) Press in the new one. I usually use the old seal as a driver for the new one.
4) Enjoy your favorite adult beverage.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 9 Old 11-18-2008, 01:55 PM Thread Starter
JeepYJ187
It looks like that knucle thing would be in the way or does the whole shaft come out of the transfer-case?
post #6 of 9 Old 11-18-2008, 01:57 PM
NJHCx4xLIFE
Not to hijack but I need to do the exact same thing on my dads yj... do I need to drain the fluid first or can the seal be replaced without drainign and refilling?
NJHCx4xLIFE is offline
post #7 of 9 Old 11-18-2008, 02:00 PM
aaronc88
can be replaced without drainging completely.
u will lose some fluid but not all of it.
My work
aaronc88 is offline
post #8 of 9 Old 11-18-2008, 02:02 PM
aaronc88
u can work around it with a regular seal puller
if u realy want to undo thos 3 bolt and take off the tailcone housing than fix it outside of vehicle.
My work
aaronc88 is offline
post #9 of 9 Old 11-18-2008, 04:33 PM
Rock Dawg 97124
I have a couple close up pics of what they are talking about. they are a little blury, It's a SYE kit; but I hope it helps..
97 Jeep: 5.0 HO,13"lift, 39.5" Swampers, Air Lockers, 4.88's, Disk Brakes, 9500 Lbs Winch, recovery tools .
Rock Dawg 97124 is offline
Transfer Case Leak Shane64 TJ Wrangler Technical Forum 12 05-28-2008 07:30 PM
Transfer Case Leak smok3y YJ Wrangler Technical Forum 16 03-08-2004 11:30 AM
Transfer Case Leak... Bighaeb YJ Wrangler Technical Forum 2 05-10-2003 09:44 PM
Transfer case leak???? nalis YJ Wrangler Technical Forum 5 03-03-2003 05:48 PM
Transfer Case Leak BamaRulz YJ Wrangler Technical Forum 3 02-23-2003 09:18 AM
