Transfer case help - JeepForum.com
post #1 of 11 Old 03-04-2013, 11:32 AM Thread Starter
Ryfree94
Transfer case help
I have not checked the Fluid in my transfer case since i bought my jeep. but does anybody know where i can look to check? and if so how do i fill it?
Ryfree94 is offline
post #2 of 11 Old 03-04-2013, 11:34 AM
kaitlynsdad
mine has a plug on the back side like a 19mm if it runs out of the hole its full if not add a little i use auto tranny fluid
kaitlynsdad is offline
post #3 of 11 Old 03-04-2013, 11:39 AM
SeanB95YJ
^^^ this
but to clarify, there should be TWO plugs... remove the TOP one and you might get a bit if fluid dribbling out... or stick a finger inside and JUST below the plug you should feel the fluid. if you get none dripping out or can't feel it on your finger, then you need to put more.... and like the above mentioned, the T-case takes ATF
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 11 Old 03-04-2013, 11:39 AM
Michaelgoesrawr
There are two bolts in the back of it. Open the top one, mines like 32mm I think and see where the fluid is. It'd be a good time to drain and replace while you're there. If you decide against replacement just add more ATF until it comes out of the fill hole on level ground.
Michaelgoesrawr is offline
post #5 of 11 Old 03-04-2013, 02:15 PM
USMCBuckWild
It may have HEX plugs. You will need to use a 1/2" (if I remember correctly) allan wrench to get them out. Same as above, undo the higher one.
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #6 of 11 Old 03-04-2013, 03:10 PM Thread Starter
Ryfree94
Thanks guys ill give it a look.
Ryfree94 is offline
post #7 of 11 Old 03-04-2013, 03:13 PM
jaycal3
There is a write-up in the FAQ about how and where and why and all that. I am pretty sure its 30mm but may be wrong... Either way, crawl under and look at the back of the TC for 2 hex shaped plugs. The top is to fill and the bottom to drain... and they are fairly close to each other.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #8 of 11 Old 03-04-2013, 05:06 PM
ryanderson
Don't worry about checking to see if it full. Just change it. It only takes about 10-15 minutes. If you dont know how to do it, theres a great step by step instructions at the top of this list in the yj section in the how to section.
ryanderson is offline
post #9 of 11 Old 03-04-2013, 06:05 PM
timatoe
timatoe's Avatar
It's a 30mm like jaycal mentioned, fill it till it's full using the top spot.
timatoe is offline
post #10 of 11 Old 03-04-2013, 06:11 PM
Siva283
Also it only holds 2.2 quarts of atf. It doesn't take much. I qould suggest just changing it. Its cheap peace of mind.
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #11 of 11 Old 03-04-2013, 06:57 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/b...hange-1009078/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
