Transfer Case and front drive shaft just exploded... why? - Page 3 - JeepForum.com
post #31 of 34 Old 12-20-2011, 10:45 PM Thread Starter
rat9
So are drop-transfer-case kits to help with driveline angles in the back, and NOT to give more clearance for the front driveshaft?
I will probably notch my cross-member for a beefier front shaft just to be safe.
rat9 is offline
post #32 of 34 Old 01-05-2012, 01:04 AM Thread Starter
rat9
Drive shaft guy
I had a long talk with a driveline shop and apparently they were not surprised at all that a front stock jeep drive shaft failed like this. It is relatively long and quite fragile. So let this be a lesson to you other people considering limping home on a freeway. If you have big tires and a I6, maybe replace that wimpy little stock shaft and save yourself the $2000 I just spent on parts.
rat9 is offline
post #33 of 34 Old 02-22-2012, 02:07 PM Thread Starter
rat9
rat9 is offline
post #34 of 34 Old 02-22-2012, 03:07 PM
Louie4
Thank you Tom Woods.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
drive shaft , exploded , front drive shaft , transfer case
Bolt size for front drive shaft on transfer case side UrbanGator TJ Wrangler Technical Forum 7 05-13-2014 12:32 PM
Sound from front drive shaft/transfer case. kylelikewhoa TJ Wrangler Technical Forum 3 12-01-2010 07:46 AM
Removing transfer case, front drive shaft Urb4nTr0ll YJ Wrangler Technical Forum 2 03-08-2010 01:29 AM
Front drive shaft spins in 2 wheel and transfer case won't go into 4 h or 4 l laxplayerr12 YJ Wrangler Technical Forum 2 11-21-2009 02:50 PM
Front drive shaft/transfer case specs prljeep TJ Wrangler Technical Forum 1 10-05-2009 07:26 AM
