Transfer Case Expert needed! NP231j 231 - JeepForum.com
post #1 of 6 Old 12-15-2009, 07:09 AM Thread Starter
eric411420
I have searched and searched for a long time and can't find an answer to a few of my questions.
I have a 94 YJ, 4.0, Manual trans, NP231j.
I noticed a clicking noise upon deceleration regardless of whether the clutch is in or out, trans in gear or neutral, doesn't matter. It makes the clicking in all those situations. It is vehicle speed dependent. I would roughly say that I have to be moving 25-30 mph before it will make the noise (I want to stress that it SEEMS that is the case but it is possible that I can't hear it at lower speeds). HERE, is what should be most helpful; If I put the Transfer case in Neutral, put the transmission IN GEAR (5th yields the best results) with the engine running I can hear it really well. I crawled under it and stethescoped the trans and the tcase in every spot possible and I have located the area that the noise is most prevalent. It is at the bottom of the case about an inch or so from the detent plunger/spring cap, toward the centerline of the case. I have taken the case apart for inspection and I have not found anything that is obviously wrong. PLEASE HELP!
I have some other questions relating to this issue but I don't want to get this thread sidetracked. I also think that my other questions are such that others could benefit from the answers greatly in the future so I am going to post them in a separate thread. If you see that, just realize that I am not over-posting the same thing. I am doing it to hopefully help others in their future searches as it would have been extremely useful info to me.
Thanks in advance!
Eric
When seconds count, the police are only minutes away.
eric411420 is offline
post #2 of 6 Old 12-15-2009, 09:02 AM Thread Starter
eric411420
I also meant to say that there is no sign of the chain contacting the case as well. What parts are moving inside the case when it's in neutral with the trans in gear? I have dana 44's and manual hubs. I am correct that vacuum issues only apply to the stock diff and not the tcase? The P.O. installed an SYE but also left out the magnet and detent plunger spring. I now don't trust much in this case.
post #3 of 6 Old 12-15-2009, 09:14 AM
TSEJEEPERS
Are you sure the noise is coming from the transfer case and not the driveshaft? Maybe you have a u joint going out.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 6 Old 12-15-2009, 10:15 AM
rosco_dog
did you reinstall a spring? it's there to keep the shift fork in the right spot. this might be your problem. I'm assuming the above test was done with the jeep parked and not driving? So that would rule out ujoints.
'90 YJ, 350/700R4/231CJ swap in progress, stock axles currently with 4.88's and 33's
rosco_dog is offline
post #5 of 6 Old 12-15-2009, 01:12 PM Thread Starter
eric411420
The spring is definitely in there and you are correct, the jeep was stationary. The rear shaft, cv and u-joints are new and it was just balanced.
What is in motion inside the tcase when it is in neutral but the trans is in gear and rotating? The only thing I have not taken out is the planetary gear drive. I can grab it and there is a little play. How much play is normal?
post #6 of 6 Old 12-15-2009, 11:33 PM
rosco_dog
i had the same problem once, i sold the jeep before i could figure it out though. i sent you a pm.
Np231j transfer case trouble shooting Blackfish YJ Wrangler Technical Forum 10 08-15-2014 02:27 PM
Transfer Case lowering kit needed? thegreatnardini YJ Wrangler Technical Forum 15 07-14-2008 01:37 AM
Trans/Transfer case needed docneon TJ Wrangler Technical Forum 1 02-28-2008 06:33 AM
Replace YJ Transfer Case NP231J jeephobbie57 YJ Wrangler Technical Forum 11 07-21-2007 05:01 PM
more transfer case info needed PLEASE! cutlass1972 TJ Wrangler Technical Forum 3 12-21-2006 08:21 AM
