Quantcast Transfer Case Drop Question...To drop or not to drop? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Transfer Case Drop Question...To drop or not to drop?
Old 07-23-2009, 09:24 PM   #1
dswi
91 YJ, 2" body lift, Stock Leaf springs, raised shackles (yes, I know they are bad on springs!), I did a transfer case drop this morning...lowered it about 2" evenly with 6 spacers and new bolts/washers.
On the actual T/C drops, are all spacers the same or are they larger in the front and smaller in the back?
I haven't driven it since the T/C drop, but I am trying to eliminate a vibration to do with the drive train around 50-55 mph...
Should I keep this even T/C drop in place or take it out?
By the way, I also have a broken driver side motor mount that is being replaced by me tomorrow morning.
Thanks for the input
Character is Who You Are When Nobody Is Looking!!
Darrin
dswi is offline   Reply With Quote
Old 07-23-2009, 10:03 PM   #2
provinT13
How big are those shackles? You shouldn't be getting vibes with stock suspension and some shackles. It may be a different problem with worn u joints or something of that nature.
2 Hands Working Do More Than 1000 Hands Praying
94 YJ Build
99 TJ Build
provinT13 is offline   Reply With Quote
Old 07-23-2009, 10:04 PM   #3
johnboy68
Will Work for Parts
johnboy68's Avatar
The TCase drop kit that came with my lift consists of two 2X2 square tubes the length of the skid (one for each side) with pre-drilled holes. They are not tapered.
johnboy68 is offline   Reply With Quote
Old 07-23-2009, 10:16 PM   #4
dswi
Shackles are probably about 6" center of bolt to center of bolt.
U-joints seem tight (when hand shaking/pulling)
If i "get off of the gas" when the vibration occurs it goes away (I am thinking that this means that it is not to do with the tires/balancing.)
Doesn't matter the gear 4/5 it occurs at about the same speed.
What is the worst that can happen if I leave the T/C drop in?
It does seem to straighten the rear driveshaft a little.
I have not driven it since the drop that I did this morning.
Jeep is at work now...I will see it again in the morning.
Darrin
Old 07-24-2009, 05:41 AM   #5
dswi
Here are some pics if it helps any...
Darrin
Old 07-24-2009, 09:01 AM   #6
TSEJEEPERS
Just leave it for now. You said you have a broken motor mount. That may be what is causing your vibes.
You may also want to check you transmission mount.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Old 07-24-2009, 10:07 AM   #7
Louie4
Injanir
Louie4's Avatar
I don't think there should be much vibration with your set up there. The shackles are 2" longer than stock so you're getting about 1" of lift there, but I wouldn't think it would cause too much vibration, especially if you drop the t-case. If I were you, I would try swapping the wheels around (cheap way to diagnose) and check the transmission mount as said above and the stabilizer bushing on the drivers side of the tranny. See how the motor mount helps too.
Lou
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Old 07-24-2009, 11:38 AM   #8
dswi
OK, I have removed the transfer case drop...Didn't even crank it up with the T/C drop in place!!
Noticed (thank you TSEJEEPERS) that the Transmission mount is also cracked...The Transmission stabilizer....Should that be bolted to the bottom steel plate??
It isn't.
Thanks again Jeep Forum for saving the day with much needed information.
Darrin
Old 07-24-2009, 12:57 PM   #9
provinT13
Yes it should be bolted to your t-case skid plate
94 YJ Build
99 TJ Build
Old 07-24-2009, 01:22 PM   #10
J-Quad
It isn't.
dswi,
How about posting a pic of your transmission stabilizer 'being bad'?
J-Quad
-- '95 YJ, 4-cyl, 5-speed.
From Dec-Mar, it wears an 80" snowplow. From Apr-Nov, it likes to go 2-tracking!
"War does not determine who is right, war determines who is left."
J-Quad is offline   Reply With Quote
Old 07-24-2009, 01:57 PM   #11
dswi
Originally Posted by J-Quad View Post
dswi,
J-Quad
There should be a nut on the bottom of this...Correct??
Sorry for the horrible picture. I don't think that the rubber on this is actually broken...but I do know that the transmission mount has a visible crack in it.
I am hesitant to replace it before determining the actual problem (what caused it to crack...besides 18 years of force...and a NON-MECHANICALLY INCLINED PO having the Jeep since 1997!)
Vibration still exists...BTW.
Darrin
Old 07-24-2009, 03:33 PM   #12
Louie4
Injanir
Louie4's Avatar
Man, you're lucky on the stabilizer stud. The nut on mine was gone and it took the threads with it. If I were to guess, I'd say the transmission mount got oil soaked, expanded and deteriorated. Either way it sounds like you need to replace the trans mount. I would do that then see what happens. Plus put a nut and a big washer on that stud. It keeps the tranny from rotating when taking off.
Lou
Glock Forum
