Transfer case boot for 231c transfer case in jeep wrangler
#1 | |
Hi i have been doing a 350/700r4/231c swap in my 89jeepyj. Everything has been ok. Wondering what everyone else is using as a shifter boot for the 231-C transfer case. I used a B&M floor shifter for the tranny but have not came up with any good sutable ideas for the transfer case. Has anyone else? If so some pics or suggestions would be greatly appreciated.
#2 |
Head Brewmaster
I just found a cheap floor shifter boot at my local auto zone and screwed it down with zip screws
92 YJ. High Output 4.0L Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods My RigRater Score: 682RRv1.0 with a BOA of 13.47 I'm now doing custom bumpers and lift installs in So-cal |
#3 |
XJ on 37's
i actually used the stock s10 boot. worked great.
you will need to make a new sheetmetal panel for the new shifter location, at least i did. after that just use self drilling machine screws through the metal base of the boot and off ye go! the s10 shifter boot... ![]() a REAL shifter setup! ![]() martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
