Transfer Case - JeepForum.com
post #1 of 6 Old 07-22-2001, 02:23 AM Thread Starter
bigjeep39
bigjeep39's Avatar
Transfer Case
Hey, does anybody have a clue on how to lower a transfer case on an 89 Wrangler, 258 6cyl. It came with the Rubicon 4" Lift,.
Thanks Shawn
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 6 Old 07-22-2001, 04:42 AM
bigblueyj
get a floor jack and also block of wood to help support the x-case skid plate and loosen the 6 bolts (3 bolts on either side just so there loose and not all the way out on one side take out the bolts and put the spacer(s) and then just barely tighten them do the same thing on the other and then when you have both of the spacers on either side tighten all the bolts up and your done hopes helps
bigblueyj is offline
post #3 of 6 Old 07-22-2001, 11:07 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
You'll have to use a reverse torx socket for the bolts that go into the frame rail. Go easy on removing them. Soak them with some penetrating oil first and you may have to use a long pipe on a breaker bar to break the bolts loose. Also, make sure to check the clearance on your shift levers when you do lower the T-case. When I lowered my 89' yj T-Case 2" the shift lever would hit the metal band around the shift boot when in reverse. This didn't allow reverse gear to fully engage. After about 1 month of driving it this way, I was pulling the tranny to put in a new reverse gear.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 6 Old 07-22-2001, 04:24 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Hey, thanks a bunch guys, oh and one last thing where do the degree shims go, Thanks again. I appreciate it.
1998 TJ
post #5 of 6 Old 07-23-2001, 12:45 AM
FLHT_FXRS_YJ
The degree shims go between the rear axle and the u-bolt mounting plates. The shim should be placed over the spring centerbolt head, with the thick end forward. The idea is to have the axle rotate up toward the t-case a few degrees to help on driveline angles.
post #6 of 6 Old 07-23-2001, 02:49 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Thanks, i appreciate it. It is a lot more understandavle now.
1998 TJ
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 02:28 PM
Bent rear diff and cracked transfer case, what diffs and case will bolt into my 87 YJ hillside250 YJ Wrangler Technical Forum 9 01-08-2009 01:45 AM
transfer case issues 91 auto to 88 standard case... input shaft?? dream911tommy YJ Wrangler Technical Forum 1 12-22-2008 12:23 PM
transfer case shift linkage problems after t-case drop heezy101 TJ Wrangler Technical Forum 5 08-29-2006 07:02 AM
Diff and transfer case fluid transfer hint BillArf TJ Wrangler Technical Forum 11 06-26-2005 08:42 AM
