Transfer Case - JeepForum.com
post #1 of 5 Old 04-10-2013, 07:55 PM Thread Starter
digizure
Transfer Case
Hey, I busted my NP231 transfer case and I'm considering replacing it with a dana 300. I will get the dana 300 flip kit and 4 to 1 lomax gears. I currently have 8.8 in the rear and dana 30 up front (from a cherokee so there is no vacuum).
What I wanted to know is, would the dana 30 handle the 300? I'm running 35s and do not plan to go bigger.
Thoughts? Thanks!
digizure is offline
post #2 of 5 Old 04-10-2013, 08:27 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Its tires you need to worry about, not the transfer case. I run 36's hard on my Dana 30 but I have thrown all the money I can into it sans a truss. The key is to create a weak link outside the ring and pinion. I prefer a cheap ujoint in each driveshaft to act as a fuse that will pop before something expensive does.
How have you built your 30?
Luck Favours The Prepared
Anticanman is offline
post #3 of 5 Old 04-10-2013, 08:30 PM Thread Starter
digizure
Everything is pretty much stock. It is a high pinion and I put in 4.88 gears. Also aussie locker. It does the job for what I usually do. I plan to add a truss someday soon.
digizure is offline
post #4 of 5 Old 04-10-2013, 08:31 PM Thread Starter
digizure
I also have spare shafts for the d30 - have not used them yet. *crossing fingers*
digizure is offline
post #5 of 5 Old 04-10-2013, 08:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I think your tiny pinion will be the first to strip. I'm hoping it doesn't but watch it carefully.
