Transfer Case - Page 2 - JeepForum.com
post #16 of 23 Old 04-10-2010, 04:53 PM
2uraven
cajuns right with the back half of the case off it will be loose. if your teeth are broken you may have a bad bearing. i got a complete bearing, seal rebuild kit and a chain for about 180 bucks threes weeks ago from east cost gear. (now is a good time to do the sye. complete kit with tom woods shaft from 4x4 group buy with for 460 bucks) just a thought if you have the doe
2uraven is offline
post #17 of 23 Old 04-10-2010, 05:59 PM Thread Starter
tammaru
Great. I will def. check the teeth.
tammaru is offline
post #18 of 23 Old 04-14-2010, 07:30 PM Thread Starter
tammaru
So I took the whole transfer case apart and checked the teeth of every gear in there, they all look fine. The nylon pads on the forks are intact with no wear... I'm replacing the chain just because I heard chain clanking for a long time before this happened, plus it has 200,000 miles on it so it can't hurt.
What else could this be? I looked in the differential and everything looks good in there also. Nothing broken, everything moves without noise and no missing or broken teeth. Tranny? That's what I thought originally, but I have no issues shifting, it would stop go stop go (it was almost as if it was losing power, but the engine was running fine, no idle problems) in every gear.... then I'd keep the gas down and it would make a horrible noise, metal clanking (not in rythym) like something was breaking and then it would go a bit again, then it would repeat. Next morning, it drove fine again. I'm at a loss. Unforunatly I didn't throw it into 4WD and see what happened.
I'm going to put it all back together tomorrow and see what happens unless someone else here has another idea, I'm out of them.
tammaru is offline
post #19 of 23 Old 04-14-2010, 08:07 PM
2uraven
that sounds notgood! I would check your trany bolts , but that doesnt explain the loss of power. what does the oil in your engine and trany look like? Is the sound like a knocking? I hate guess something like a spun rod bearing, but...try reposting this also. someone might have had a problem like this that was no big deal.
2uraven is offline
post #20 of 23 Old 04-14-2010, 08:23 PM
DaveinHouston
That chain isn't bad enough to cause those symptoms. In fact in the photos the chain looks pretty good.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #21 of 23 Old 04-14-2010, 08:50 PM Thread Starter
tammaru
Never thought of checking the tranny bolts, will check tomorrow. Engine oil is nic and clean, I change it every 3000-4000 miles. Tranny oil looks the same, it was changed late last year. It's not a knocking, it's like someone hit something below me with a hammer, it's not constant, it does it once or twice each time this happens.
tammaru is offline
post #22 of 23 Old 04-14-2010, 08:58 PM
2uraven
the loss of power is a mystery but sometimes my cross member mounts make noise but not like that. a long time back i had a 78 chev 3/4 ton that i replaced the trany in. i didnt tighten the bolts enough and it made a hell of a sound when i hit a bump just right.
2uraven is offline
post #23 of 23 Old 04-17-2010, 11:19 AM Thread Starter
tammaru
Well, I replaced the chain and the chain noise is gone. Replaced the fluid in tranny with synchromesh and put everything back together. Driving around so far, everything is working well, but I don't think I actually fixed the issue. we'll see I guess. Thanks to everyone who chimed in and tried to help!
TJ
tammaru is offline
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 01:28 PM
Bent rear diff and cracked transfer case, what diffs and case will bolt into my 87 YJ hillside250 YJ Wrangler Technical Forum 9 01-08-2009 12:45 AM
transfer case issues 91 auto to 88 standard case... input shaft?? dream911tommy YJ Wrangler Technical Forum 1 12-22-2008 11:23 AM
transfer case shift linkage problems after t-case drop heezy101 TJ Wrangler Technical Forum 5 08-29-2006 06:02 AM
Diff and transfer case fluid transfer hint BillArf TJ Wrangler Technical Forum 11 06-26-2005 07:42 AM
