Trans swap to AX-15 - JeepForum.com
post #1 of 6 Old 07-31-2002, 08:45 AM Thread Starter
johny1i
johny1i's Avatar
Trans swap to AX-15
Hey guys,
Found a good deal on an '89 Sahara (would make a good second/wife vehicle), but I'm a little skeptical due the stories I've heard about the Peugeot transmission and how hard it is to find parts, weakness, etc. Anyway, I'm wondering what it entails to swap in an AX-15--different bellhousing, new floor cutout, same clutch system? Is the rear transmission mounting surface the same as an AX-15; hence, will it mate to the NP-231, and at the same length, or do I have to get new driveshafts?
Thanks a lot for any info--
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #2 of 6 Old 07-31-2002, 11:01 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I understand that the basics of the BA10 and AX15 are the same, but if you do the swap, make sure that you get everything with the tranny.
The bell housing I understand is the same, but you might need to chage the output (or input) shaft between the tranny and t-case (different spline counts).
I am sure that this change over was discussed about 2 weeks back .. do a quick search .. you should find it.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 6 Old 07-31-2002, 11:53 AM Thread Starter
johny1i
johny1i's Avatar
Thanks Naekid, that's exactly what I needed to know. I check this thing everyday but I guess I just missed that thread .
johny1i is offline
post #4 of 6 Old 07-31-2002, 07:13 PM
NaeKid
NaeKid's Avatar
I know you are here everyday .. I am tryin' to keep ahead of your post count .. and its getting harder and harder to do so
Silver
NaeKid is offline
post #5 of 6 Old 07-31-2002, 08:57 PM Thread Starter
johny1i
johny1i's Avatar
Dude, I'll never catch up to 845, I'm only good for engine talk and the occasional BS on here . Anyway, I've done my research today and it comes down to about 3 choices:
NV3500 from Advance Adapters including everything necessary (even the trans fluid) - $2225 (and they mention a 13-degree TC angle versus the stock 23-deg angle of some configurations which means that it may rub the skid plate, and makes me a little apprehensive--as if the cost isn't enough!)
Rebuilt Peugeot with 1 year parts and labor warranty from local salvage yard - $1450 (and I'd still have an inferior transmission)
Rebuilt AX-15 from same salvage yard - $1100, plus bellhousing, slave cylinder, as necessary
I read some posts that some guys found used AX-15s for as little as $300, but I just don't know about this--seems like a lot of money to put in a YJ. Especially considering that the guy at the salvage yard just bought a 1988 with 4.2, AC, and auto trans for just over $2000. Why don't I ever come across those deals??
johny1i is offline
post #6 of 6 Old 07-31-2002, 10:49 PM
NaeKid
NaeKid's Avatar
Them BA10's are worth that much!?!?
I gave my tranny and t-case away for $300 as a matched pair when I went to Chevy power! I figured my NP231 was worth something (it was just rebuilt a couple months earlier) .. but the BA10 I just tossed in to sweeten the deal ..
Ooopps.. maybe I should have asked for a little more money ..
Silver
NaeKid is offline
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 09:30 AM
some ?s on engine swap or trans swap mdf27 YJ Wrangler Technical Forum 3 06-07-2008 09:24 AM
Trans swap 87 JEEP YJ YJ Wrangler Technical Forum 2 11-29-2003 09:09 AM
Swap automatic trans for manual trans Hammer49 YJ Wrangler Technical Forum 3 01-29-2003 01:13 PM
