Trans Swap Alignment Problem - JeepForum.com
post #1 of 14 Old 12-06-2012, 11:15 PM Thread Starter
Mr.ThunderMakeR
My new trans is in but the mount holes aren't lining up in the skid plate. I expected to have to elongate the holes, but its actually off by an inch to the side. Should I just drill new holes where its lining up? I'm afraid if I do the new holes will merge with the existing slots and be too weak.
It looks like it is close enough to maybe shift it into place. Should there be enough play in the motor mounts to shift the whole drive train an inch to the side? I tried this but it wasn't seeming to budge.
Also the rear output flange looks like its off by about an inch sideways with respect to the rear axle pinion. Is this a problem? Does the rear output of the transfer case need to be aligned side-to-side with the pinion? Sorry I don't have a pic of this atm.
Mount:
Not lining up:
- '91 Jeep Wrangler YJ, 4" lift with 33" BFG KM2's, 1" body lift, NV3550 swap, NP241OR Rubicon TCase w/ Novak Cable Shifter, Monstalined Tub
- '09 Mazda RX-8 R3
Mr.ThunderMakeR is offline
post #2 of 14 Old 12-07-2012, 08:04 AM
notmyj
What do your.motor mounts look like? If they are worn it could cause this. My rule is if the motor mounts are good, shift it side to side and enlongate the holes as needed when doing a granny swap. I had to do this when I swapped in the AW4. If all things are stock, then shift it around till it fits.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #3 of 14 Old 12-07-2012, 10:17 AM Thread Starter
Mr.ThunderMakeR
The passenger side looks good, I also replaced the cradle with a brown dog cradle (yellow piece)
I'm not sure about the driver side though:
- '09 Mazda RX-8 R3
post #4 of 14 Old 12-07-2012, 10:27 AM
notmyj
driver side mount is toast. This.will cause.your problem... might as well get new mounts so your tranny mount lasts.
notmyj is offline
post #5 of 14 Old 12-07-2012, 10:49 AM
Brown Dog
Vendor
Brown Dog's Avatar
I can't see the mount well enough to be sure, but unless the elastomer is cracked it looks pretty good to me. I talked to a customer recently who had the same problem you are experiencing. In his case he had a number of P.O. issues (hack-job repairs). In you case it appears to be a straight up AX-5 replacement. The motor mounts can handle a 1" shift; don't worry about that. Be looking around to see if anything has strayed and is wedged in somewhere that would cause the shift. I'm thinking of things that might be in the tunnel, or something like that. Are you able to freely move the rear of the transfer case from left to right?
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #6 of 14 Old 12-07-2012, 11:41 AM
notmyj
there is a large gap in the driver side mount between the rubber and the metal housing. Unless I am misinterpreting the pic, it would seem this gap in the mount would cause the movement.
notmyj is offline
post #7 of 14 Old 12-07-2012, 11:57 AM
Brown Dog
Vendor
Brown Dog's Avatar
That is actually normal with the OEM 2.5 mount...believe it or not.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #8 of 14 Old 12-07-2012, 12:16 PM
notmyj
Just learned something new.
notmyj is offline
post #9 of 14 Old 12-07-2012, 12:18 PM
Brown Dog
Vendor
Brown Dog's Avatar
Yeah, your 4.0 mounts aren't like that. On the 2.5 you really have to look for cracked rubber.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #10 of 14 Old 12-07-2012, 02:58 PM Thread Starter
Mr.ThunderMakeR
Its actually a NV3550 swap, with Rubicon tcase. But I imagine the alignment should be the same. There is a little bit of wiggle side to side but not much. It feels like the motor mounts are preventing the movement. I'm gonna try loosening the motor mounts and anything else it might be bound up on and shift it into place.
Kinda like Mean Max's post in this thread:
http://www.jeepforum.com/forum/f12/m...stion-1013737/
- '09 Mazda RX-8 R3
post #11 of 14 Old 12-07-2012, 05:24 PM Thread Starter
Mr.ThunderMakeR
I tried to get a picture of the rear pinion alignment but its difficult to show clearly:
Do these need to be aligned?
- '09 Mazda RX-8 R3
post #12 of 14 Old 12-07-2012, 05:45 PM
Brown Dog
Vendor
Brown Dog's Avatar
Yes they do.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #13 of 14 Old 12-07-2012, 06:57 PM Thread Starter
Mr.ThunderMakeR
Ok thanks for the help. Ill try to get it straightened out
- '09 Mazda RX-8 R3
post #14 of 14 Old 06-13-2013, 04:54 PM Thread Starter
Mr.ThunderMakeR
Just thought I would update this for future readers...better late than never I guess. I got it lined up by using a ratchet strap around the frame and the tcase. Easy as pie.
- '09 Mazda RX-8 R3
