trans problems or speed sensor? - JeepForum.com
post #1 of 10 Old 09-19-2012, 05:16 PM Thread Starter
riverhippy
5th gear has been making noise for a few weeks. now all gears are making same sound. feels and sounds likie the gear isnt completely engaged.
i pulled a code 15 on my 91 wrangler 5 speed. which is the VSS.
i replaced the clutch few mos ago.
before i do my usual and replace 10 things that cost more than a new toilet seat on a B1 bomber ($17,000 is what the pentagon claims they cost) only to find it needed a left handed bolt for 39 cents....is the VSS capable of messing up the gears a little? or is it the trans i need to replace?
riverhippy is offline
post #2 of 10 Old 09-19-2012, 05:33 PM
Mark05059
pull the adapter housing out noting where it is orentated and check the speedometer gear. Its on an eccentric so it will fit in any position but only work correctly in one.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 10 Old 09-19-2012, 06:53 PM
pete1991YJ
^^^^ X2 Que knows all bout this one... there are a few marks on the VSS housing one of them should be the one that lines up properly. I forgot how to calculate it.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #4 of 10 Old 09-19-2012, 07:20 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Read post #27...
http://www.jeepforum.com/forum/f12/s...30/index2.html
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 10 Old 09-19-2012, 08:01 PM Thread Starter
riverhippy
im assuming that based on the response that it would affect the gears while driving?
post #6 of 10 Old 09-19-2012, 08:12 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Doesn't seem likely to affect the gears. The drive gear (metal, unless you put in an SYE kit), drives the driven gear (plastic) as the main shaft turns. This is all back on the T case. Should have no effect on your transmission gears.
The AX5 does have a history of dropping the 5th gear snapring, but it doesn't sound quite like that is going on either.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #7 of 10 Old 09-19-2012, 08:13 PM
Mark05059
the speedometer gear may be disintegrating internally (read plastic in the gearing)
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #8 of 10 Old 09-19-2012, 09:20 PM Thread Starter
riverhippy
ok...im gonna put it up and listen for exactly where its coming from.
post #9 of 10 Old 09-19-2012, 09:33 PM
Opihi59
Opihi59's Avatar
Is your tranny fulla lube? You aren't running it dry are you?
And T case.
Opihi59 is offline
post #10 of 10 Old 09-20-2012, 10:24 AM Thread Starter
riverhippy
And T case.
they were full when i put it back in few mos ago. if it developed a leak I'm about to find out.....
bigboobslittlelegs , hot asian butt , hot chick , tranny problem
trying to do disc brake swap and having problems with speed sensor help! mgaither0 TJ Wrangler Technical Forum 15 11-25-2014 10:02 PM
2006 tj, six speed trans. Swap to 5 speed? Vinnie911 TJ Wrangler Technical Forum 11 07-24-2012 08:52 PM
3 speed auto to 5 Speed Stick Trans Swap GPERSCREEPERS99 TJ Wrangler Technical Forum 10 09-08-2011 04:01 PM
1992 speed speed sensor???? mij3 YJ Wrangler Technical Forum 1 07-21-2008 07:57 PM
Converting 5 speed trans to 6 speed cyclerider105 TJ Wrangler Technical Forum 21 07-08-2007 10:29 PM
