TRANS PROBLEMS - JeepForum.com
post #1 of 4 Old 07-18-2001, 12:40 PM Thread Starter
GREGDOG95YJ
GREGDOG95YJ's Avatar
TRANS PROBLEMS
I have a 95 yj with the 4cyl. and ax-5.
I started having problems shifting second gear (upshift & downshift) I changed the gear oil but it helped very little. does anyone have any suggestions? Also, has any one had any experience with the nv3550 tranny
in the new tj? Is it a good choice for a swap?
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #2 of 4 Old 07-18-2001, 04:07 PM
rayray
rayray's Avatar
Sounds like your syncro's are going.
If your gonna swap, go NV4500 The only problem is matting it to a 4 banger.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #3 of 4 Old 07-19-2001, 09:50 AM Thread Starter
GREGDOG95YJ
rayray, thanks for the help suggestion on the tranny problem I looked on a web site last night and it sells the nv4500 and adapter kit for a 4banger yj for between $1800 - $2000 bones. If you want to see for yourself at www.tellico4x4.com. They also had good pricing on winches.
Jason Gregory
post #4 of 4 Old 07-20-2001, 02:03 AM
I-4
I-4's Avatar
I've got 95 2.5,with the illustrious ax-5.the tranny started giving me fits in several gears.unfortunately if 2nd is going other gears won't be far behind.i had to go w/ a rebuilt tranny i wanted to do a nv 4500---one of these days!
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
trans problems on a 97 help black 97 tj TJ Wrangler Technical Forum 8 03-07-2008 09:46 AM
AT Trans problems Manimal YJ Wrangler Technical Forum 1 07-10-2006 06:41 PM
trans problems brundz YJ Wrangler Technical Forum 2 03-25-2006 08:11 PM
Trans Problems I think? RescuedJK TJ Wrangler Technical Forum 4 09-25-2005 08:49 PM
Trans(ax5) Problems Bradshaw1994 YJ Wrangler Technical Forum 7 03-12-2003 04:02 PM
