trans problem need HELP - JeepForum.com
post #1 of 7 Old 02-03-2002, 04:45 PM Thread Starter
jeepguy616
problem started a week ago. I have a 87 yj with the Peugeot transmission. It was getting hard to get in gear. My first attempt was to bleed the master cylinder. This seemed to help for about 15 miles and problem came back. Next I replaced the master cylinder and bled the system again. helped for about 5 miles and got bad enogh to where it would not go into gear at all. when the motor is running it will not go in gear but with the motor shut off it will go in gear. HERES THE KICKER, I put the trans in gear with the motor shut off and then depressed the clutch to start and turned the key and as it turned over the jeep started to move. Some how the clutch is not depressing all the way. HELP? does this have to deal with the clutch or something else? Is there a inspection plate to check the clutch? Thanks
jeepguy616 is offline
post #2 of 7 Old 02-03-2002, 11:13 PM
SFM1AE2
I have an 87 with the same tranny. I haven't had a problem yet but It has to be the hydrolic clutch mechanism. Let me know what happens.
87YJ I-6 Offenhauser intake Holley 4bbl MSD 6AL box
SFM1AE2 is offline
post #3 of 7 Old 02-04-2002, 01:27 AM
FLYBYU
It's not a problem with your tranny, its the clutch thats had. I just had the same problem with a 94 YJ that I just bought. The master cylinder on your clutch is gone so when you depress the clutch pedal it dosen't actually depress the clutch, thats why when you put it in first to start it and depress the clutch the truck moves anyway, you don't have a clutch. I would suggest doing the same as me and getting it towed to the nearest dealer, it's awful hard on you starter starting it in gear and you can't shift up or down without hurting the tranny. The dealership is picking up the cost for mine cause I only bought it a week ago, but it will cost them over $1000 Cnd, Ouch! I wish you the best of luck and hope it dosen't cost you too much.
94 Jeep YJ 4.0L HO 5 speed
88 Nissan Pickup 2.4L Lowrider
67 Ford Fairlane 500
FLYBYU is offline
post #4 of 7 Old 02-07-2002, 04:47 PM
BTowe
BTowe is offline
post #5 of 7 Old 02-07-2002, 04:50 PM
BTowe
The Peugot Transmission is a very weak tranny. If you haven't had trouble yet, you will. I spent $700 on a complete rebuild 18 months ago and had to tow my Jeep in last night because it went out again. I'm looking for some kind of bolt on replacement that will work with my x-fer case and drice shaft. Does any one know what that might be?
BTowe is offline
post #6 of 7 Old 02-07-2002, 04:57 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Internal slave cylinder or clutch. If your clutch pedal moves too easily its the slave cylinder. If your clutch pedal is the same as it always was and your not losing any fluid, then it's the clutch. Either way, you have to pull the tranny and transfer case to get to the clutch and slave cylinder.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #7 of 7 Old 02-07-2002, 07:27 PM Thread Starter
jeepguy616
Thanks guys, I will have to start tearing it down. Looks like the clutch seeing as how my clutch pedal still seems the same and no fluid loss. While I have it apart I will change slave cylinder also.
I think I will be looking in to a ax-15 tranny so that I will be able to put the slave cylinder on the outside. Thanks again
92 AX-15 Trans Problem sahara tj YJ Wrangler Technical Forum 13 03-08-2009 05:46 PM
Trans problem newtjrjrjr YJ Wrangler Technical Forum 1 12-16-2008 08:29 AM
ut oh- I have a trans problem hammer99tjdd TJ Wrangler Technical Forum 16 06-14-2007 07:22 AM
trans problem mattiemo TJ Wrangler Technical Forum 3 06-11-2007 01:59 PM
trans problem markc522 TJ Wrangler Technical Forum 4 01-09-2006 04:10 PM
