trans keeps popping out of first! - JeepForum.com
post #1 of 24 Old 01-30-2013, 07:48 PM Thread Starter
Exit93
so about the last week now when i take off from a stop my trans usually pops out of first gear. it doesn't happen every time but its becoming more frequent now. what could it be? am i doing something wrong? could it be because of the cold? i'm from Chicago, so it pretty cold this time of year, am i low on trans fluid?
Exit93 is offline
post #2 of 24 Old 01-30-2013, 08:29 PM
jokerchief462
Check the fluid level but something is vibrating the stick enough to knock it out of gear. So I would believe if it is not cold related or fluid maybe first gear is coming appart or starting to vibrate. Best I got.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 24 Old 01-30-2013, 08:42 PM Thread Starter
Exit93
how do i check the trans fluid?
Exit93 is offline
post #4 of 24 Old 01-30-2013, 08:43 PM
Bnabb
Synchros
Bnabb is offline
post #5 of 24 Old 01-30-2013, 08:45 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by Bnabb View Post
Synchros
Yes.
http://www.jeepforum.com/forum/f12/b...change-865520/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 24 Old 01-31-2013, 08:58 AM
Siva283
Originally Posted by Mean Max View Post
Syncro's can cause it to pop out of gear? I thought they were only involved during the engaugment of the gear and were out of the pic once fully into gear?
Ask me how I know...
Siva283 is offline
post #7 of 24 Old 01-31-2013, 09:00 AM
alexs93
Could also just be as simple as the boot getting extremely cold. Mine has popped out of first just from the rubber being too stiff from the cold.
alexs93 is offline
post #8 of 24 Old 01-31-2013, 12:06 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes. If the syncro is worn away at the 3 recesses where the syncro hub keys engage the syncro, the syncro can rotate out of position & prevent complete gear engagement. When a load is applied under these conditions, the hub sleeve will typically pop back away from the selected gear.
Max
Mean Max is offline
post #9 of 24 Old 01-31-2013, 02:56 PM
Siva283
Max
Interesting. Thanks for the info Max.
Siva283 is offline
post #10 of 24 Old 01-31-2013, 11:36 PM Thread Starter
Exit93
How much $$$ are we talking to get it fixed?
Exit93 is offline
post #11 of 24 Old 01-31-2013, 11:40 PM Thread Starter
Exit93
how did you figure this out?
Exit93 is offline
post #12 of 24 Old 02-01-2013, 05:53 AM
coolin4u
This is what it was with mine,i had problem with it popping out of reverse and 2nd,would get a little better once everything got good and warm, so i just took mine loose from the floor and drove it and no more problem.i ended up getting an old used one to replace the new stiff one that PO had installed,this problem didnt show up till it got down around freezing
coolin4u is offline
post #13 of 24 Old 02-01-2013, 07:08 AM
willawolfe
Another vote for the shift boot. At least it would be a cheap fix if it's your problem. When cold my shift boot makes it more difficult to get into 2nd gear. (do you have a body lift)?
willawolfe is offline
post #14 of 24 Old 02-01-2013, 10:29 AM Thread Starter
Exit93
I'll try removing the boot. Hopefully that's the problem. I'll let you guys know if it works
Exit93 is offline
post #15 of 24 Old 02-01-2013, 12:08 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Definitely try the boot first!
Max
Mean Max is offline
