trans issue - Page 2 - JeepForum.com
post #16 of 19 Old 12-26-2012, 06:33 PM Thread Starter
Bigones1993
well with all work done the clutch is a bit stiffer but it still clashes gears and every so often i have to reapply the clutch to get into first
95 YJ Wrangler
92 XJ Cherokee Sport
02 WJ Grand Cherokee (Sold)
69 Jeepster Commando (Gone)
Bigones1993 is offline
post #17 of 19 Old 12-26-2012, 06:43 PM
trboxman
1987 YJ Wrangler
Sounds like your 1st gear synchro is not healthy.
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline
post #18 of 19 Old 12-26-2012, 06:46 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Got good pedal? Sure it is completely bled? Can try bleeding more, keep res full as it is tiny. Have heard of others pumping clutch pedal like a thousand times to work air out but I'm more comfy with the conventional way.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #19 of 19 Old 01-02-2013, 03:21 PM Thread Starter
Bigones1993
i filled the trans with fresh fluid to day it helped a little atleast i can get into first a lot easier but it still grinds if i pump the gas between gear changes it wont grind but will if i dont i am quite confused what to do next
95 YJ Wrangler
clutch , clutch issue , trans
