Tranny/T-Case Question - JeepForum.com
post #1 of 3 Old 07-22-2002, 06:47 PM Thread Starter
bt24drexel
OK, first, I was told the transfer case shift linkage that bolts to the tranny is the same for the 231 mated with the ax-15 and the 207 bolted to the peugot. I had the peugot and 207, replacing the set up with the other combo. Because my new ax-15/231 came from a cherokee (body mounted shifting assy) I cant use the existing linkage. It is what I think is a coincidence that the bolt pattern off of my 87 t-case shifting assy bolted to the 231 t-case. However, the throw is backwards after I hook up the rod from the selector on the tcase, where as before 2 wheel high was in the extreme forward position, it is in the extreme back position. The indexing and difference in shifter travel is not as well defined now either, making 4wd engagement a guessing game. Any ideas? Are they two different assemblies? Would unbolting selector on side of t-case (on really tight) and rotating it all the way around to where I am getting appropriate shifts work? Also, the t-case is out of a 96 cherkee, it has two lines to go to the diff, where as before, I had 4, what do I do, what controls my dash light to indicate 4wd? Also, in this swap, I am aware that I have to modify the skid plate, any exact details or hints on what I need to do to get the mout to botl to my skid plate? Thanks guys
bt24drexel is offline
post #2 of 3 Old 07-22-2002, 08:53 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Wow .. a loaded question!
The best thing to do is to find a YJ from 1992 and steal its front axle vacuum actuator and its 231 shifting setup.
The front diff vacuum actuator controls the 4x4 light on your dash. As long as the actuator moves through its normal path, the switch should work normally and the light should also work normally. If you wish to keep your actuator, you can purchase a cable assembly to do the work of the vacuum and just plug off the vacuum ports on the 231 T-case.
I have a spare T-Case skid-plate .. come on up and get it .. or there are after market ones (I believe that Currie makes one).
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 3 Old 07-22-2002, 10:26 PM Thread Starter
bt24drexel
Thanks for the info. I will keep you posted.
2wd tranny + T-case = 4wd? drummerchukb1 TJ Wrangler Technical Forum 1 12-02-2009 02:54 PM
question about tranny and t-case willtjx TJ Wrangler Technical Forum 6 10-26-2006 10:23 AM
changed tranny/ transfer case oil... question.. jeep_chinto TJ Wrangler Technical Forum 5 11-25-2005 11:40 AM
Motor, tranny, t-case, question COJAM YJ Wrangler Technical Forum 3 07-22-2005 08:44 AM
Help! Really stupid question on Tranny/Transfer Case ChrisLe@MindSpr YJ Wrangler Technical Forum 4 03-22-2005 08:02 AM
