Quantcast Tranny Swaps - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Tranny Swaps
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 04-02-2006, 09:25 PM   #1
roadragetrx
2006 KJ Liberty
Tranny Swaps
Anyone here swap in a different tranny like a np435 or a t-18 into there yj behind there 4.0 ?? If so how bad was the swap looking to do something my ax 15 is just about dead and had this one for only 6 months... Looking for heavy duty with a granny 1st All info is welcomed thanks
roadragetrx is offline   Reply With Quote
Old 04-02-2006, 10:09 PM   #2
bobbert350
maby instead u should do a heavy duty rebuild.. i dont no much about the one u have with the bolt patter... but make sur u check the bellhousing and will the one u want bolt up to it.... and the other thing is the t-18 is only a 4 speed and i believe the np435 is a 4 speed to
bobbert350 is offline   Reply With Quote
Old 04-02-2006, 10:13 PM   #3
avh
I have a t-18 in my 90. That is the 4.2 but I believe it is the same setup when mating to a tranny. The only major issue is the bell housing. I got a setup to mate from Parts Mike. I believe the part is from Adavanced Adapters. Sorry, I don't know the part number and the catalog doesn't give one that will work. Parts Mike could help you find what would fit. With the Granny 1st at 6.32, 4.3 t-case, and 4.10 (soon) r/p I will be crawling at 111 to 1. I really like the t-18. A bit limited on the highway but a nice range of gears when off road. Fairly easy to tear apart and a strong transmission. Oh, it also has an external slave which is definetly a plus.
avh is offline   Reply With Quote
Old 04-03-2006, 04:34 AM   #4
FLHT_FXRS_YJ
I did a NV4500 behind a stock 4.2 mated to a NP231 w/sye. No problems at all. New bellhousing and everything fits---- w/1 inch body lift to allow for larger tranny.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline   Reply With Quote
Old 04-03-2006, 05:17 PM   #5
roadragetrx
2006 KJ Liberty
Well right now i have the ax-15 for a tranny and am not impressed when i bought the jeep it had tranny problems no 2nd and 5th gear so i put in a rebuilt worked fine for about 6 months and now it won't go into first makes noise in neutral (grinding) and reverse has bit the big one. I am aware the 435 and t-18 are 4 speeds but that doesn't bother me i don't drive on the highway much maybe 2 times a year and live like 15 min from my work so the lower gearing will not bother me there either. Just looking for info on swapping in these and feedback about them. Thanks for the feedback
Old 04-03-2006, 05:30 PM   #6
jeepnguns
I have a t-18 behind a 350 now but before that I had it on my 258. swap was easy I used a t-18 out of a 79 f-250 2wd, a cj bellhousing and the AA transfer case kit. pretty easy. The hardest part is taking apart the tranny to put the new output shaft-in While I was at it I replaced all the bearings.
The Bell housing was off a CJ with a t-150 tranny. It has the brackets for the slave cylinder and bolts right up to the ford tranny.
The only problem you will have is you will need to rig up a crank shaft position sensor.
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline   Reply With Quote
Old 04-03-2006, 05:50 PM   #7
roadragetrx
2006 KJ Liberty
did you have to leanthen and shorten your drive shafts when you did this I'm thinking you must have too because the trannys are much shorter than the ax-15.. What problems did you run into with the install?
Old 04-05-2006, 09:08 PM   #8
roadragetrx
2006 KJ Liberty
anything else anyone has to add on this swap?? Problem advice ect??? Thanks
Old 04-08-2006, 12:11 AM   #9
doug_1994
Yeah, do your research now and round up the right parts. I did the T18 a few years ago behind my 4.0 HO. But I used the 4:1 first gear, with full intentions on finding the 6:32 version. Im now going to the NP435 they are more plentiful and a better gear. Check this out too.
http://www.novak-adapt.com/knowledge/ford_to_amc.htm
Good luck, Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline   Reply With Quote
Glock Forum
