tranny swap - JeepForum.com
post #1 of 8 Old 02-18-2012, 06:22 AM Thread Starter
chris447
tranny swap
anyone swap from auto to manual? i need a parts list
chris447 is offline
post #2 of 8 Old 02-18-2012, 06:59 AM
bsakal
I did the same swap on mine, when I swapped the entire engine / trans / transfer case from my XJ (which was a stick). If you are just doing the trans you will need:
Clutch kit
Flywheel
Pilot bearing or bushing
Clutch pedal assembly
Clutch master cylinder and slave cylinder
Transfer case for a manual trans
Front and rear driveshafts (on the auto trans, the rear one is longer, the front is shorter)
Correct transmission and t/c mounts
Floor plate for manual trans (or just cut the original one)
On mine, I had to elongate the slots in the transfer case skid plate for the mount. On ebay I found the correct t/c and trans mounting brackets, t/c case shifter, and the floor plate. I installed a SYE in the t/c and bought a Tom Woods CV rear shaft, and the local yard had the correct front shaft. For me, installing the clutch pedal assembly was a PITA. You'll have to remove the steering column and loosen some of the dash to manuever it in and out. The firewall already has a plug bolted in place where the master cylinder goes, just remove it, and install the correct m/c. You also have to ground the center terminal of the trans neutral safety switch so it will start. The outer 2 wires go to the backup switch in the trans.
'88 YJ 4.0 AX15 NP231; '97 ZJ; '69 Charger SE 383; '66 Newport 383
bsakal is offline
post #3 of 8 Old 02-18-2012, 07:05 AM Thread Starter
chris447
so i may be better off just getting a whole engine/tranny?
chris447 is offline
post #4 of 8 Old 02-18-2012, 07:10 AM
jay-h
probably.
There's all sorts of stuff that might be hard to find otherwise.
jay-h is offline
post #5 of 8 Old 02-18-2012, 07:14 AM Thread Starter
chris447
ugh JEEPS!!! i was hopin the swap would go more like playin with legos lol. just cut some here and swap it in... il b busy on craigs list for a wrecked one
chris447 is offline
post #6 of 8 Old 02-18-2012, 07:15 AM
bsakal
You don't need to get another engine if your is in good condition, but it would be better to get a trans/transfer case together if you can find one. I found a trans-t/c on craigslist when I was doing mine, I would up buying it, then selling it when I used the stuff I already had. If you get a trans from an XJ, the back needs to be re-drilled for the correct t/c clocking (position) in a YJ.
I only did mine because when I bought it, the original 4.2 had a rod knock, and the automatic trans was leaking. Since my XJ had rotted floors, and a good drivetrain, I converted my YJ to a 4.0 injected setup.
bsakal is offline
post #7 of 8 Old 02-18-2012, 07:23 AM
jay-h
Even something that looks simple, adding the clutch pedal, is more work than you realize.
jay-h is offline
post #8 of 8 Old 02-18-2012, 08:11 AM
Bedlam_YJ
1987 YJ Wrangler
The 'combo kits' are golden if you can find them. I paid $350 for an AX-15 and 231 from a cherokee when my BA-10/5 finally went. Even came with a spare driveshaft I can take to get cut and balanced!
Now if only swapping to auto was as easy as replacing my old BA-10/5 with the AX-15 was.
Bedlam_YJ is offline
Boss Lady said "No go!" on my V8 swap anytime soon, but i can swap an auto tranny in! 97casteeltj TJ Wrangler Technical Forum 60 10-31-2008 11:32 AM
Tranny Swap rkcrwln99 TJ Wrangler Technical Forum 3 07-29-2008 08:43 AM
AX5 Tranny swap? gregdukarich TJ Wrangler Technical Forum 0 03-27-2008 01:09 AM
Tranny Swap!!!!! mxracer513 YJ Wrangler Technical Forum 6 11-25-2007 08:32 PM
tranny swap grovey YJ Wrangler Technical Forum 4 04-07-2003 01:32 PM
