tranny skid/crossmember - Page 2 - JeepForum.com
post #16 of 31 Old 09-07-2013, 06:14 PM
NHfireLJ
NHfireLJ's Avatar
Check w quadratec for these http://www.quadratec.com/products/pr...rust&submit=Go
it is a lot of work and you need to have your welding down before doing spring mounts etc...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is online now
post #17 of 31 Old 09-07-2013, 06:18 PM Thread Starter
Tyler980
What would you say minimum volts/amps a welder has to be to work on the frame?
Tyler980 is offline
post #18 of 31 Old 09-07-2013, 06:21 PM
NHfireLJ
NHfireLJ's Avatar
I have an older model of this... http://www.lowes.com/pd_366784-1703-...ers&facetInfo=
works great. for projects in general you want to be able to do 1/4" thick. that'll take care of most anything you need on the jeep and around the garage...
SOLD
YJOTM FEB 2013
post #19 of 31 Old 09-07-2013, 06:28 PM Thread Starter
Tyler980
For that price I almost wonder if I should just pay somewhere to do it :P
Tyler980 is offline
post #20 of 31 Old 09-07-2013, 06:32 PM
NHfireLJ
NHfireLJ's Avatar
look on CL used... or for about $500-600 (for a frame) you might do a frame swap. Depends how bad your frame is.
PICS?
Estimate to do mine was almost $800 from a shop to do both rear frame sections. I ended up doing myself over a few months..
SOLD
YJOTM FEB 2013
post #21 of 31 Old 09-07-2013, 06:35 PM Thread Starter
Tyler980
I will take some tomorrow. Where the Driver side rear shock is mounted to frame is starting to rust away... rear track bar is disconnected from frame at driver side 'cause rust, then both sides next to gas tank on the frame are rotted out
Tyler980 is offline
post #22 of 31 Old 09-07-2013, 06:37 PM
NHfireLJ
NHfireLJ's Avatar
Hit the rest of the frame with a BFH and find the rest of the rust.... Sounds like a frame swap might be in your future
SOLD
YJOTM FEB 2013
post #23 of 31 Old 09-07-2013, 06:43 PM Thread Starter
Tyler980
Hope not. I will do that though. I'm thinking its only the rear. The mid section and front look and feel pretty solid.
Tyler980 is offline
post #24 of 31 Old 09-07-2013, 06:56 PM
TSEJEEPERS
This is a write up in the FAQ on how to replace the nutserts.
http://www.jeepforum.com/forum/f9/nu...nstall-390635/
This is where you can buy them and the bolts.
http://shop.blackmagicbrakes.com/87-...RDWARE-USA.htm
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #25 of 31 Old 09-07-2013, 07:19 PM Thread Starter
Tyler980
Thanks I bookmarked that writeup.. Only thing I may have an issue with is that I used a crowbar to pry my old skidplate off and i broke the nutsert through the frame on oneside, so the opening is probably too big at this point.
Tyler980 is offline
post #26 of 31 Old 09-09-2013, 05:57 PM Thread Starter
Tyler980
I forgot to hit it with a hammer today and I tried to get a pic of frame but my phone has no flash and even in broad daylight couldn't see anything. But I did grab this pic inside the tub under the drivers seatbelt where it rolls up. Tried to take roll off and it just broke all the bondo and other crap metal out..
Tyler980 is offline
post #27 of 31 Old 09-15-2013, 01:23 PM Thread Starter
Tyler980
I took the stock steps off and this is what the other side of the rust looks like....
Dunno what I'm gonna do about all this rust :/
Tyler980 is offline
post #28 of 31 Old 09-15-2013, 01:52 PM
NHfireLJ
NHfireLJ's Avatar
Yup... That's par for NE jeeps. learn to weld or get a new frame...
BTW, this is how I started
SOLD
YJOTM FEB 2013
post #29 of 31 Old 09-15-2013, 11:50 PM Thread Starter
Tyler980
Oof... my rear frame isn't as bad as yours is... but its starting to get there... the bottom by the shackles is a decent size hole... and on the side its starting to get soft.
Tyler980 is offline
post #30 of 31 Old 09-15-2013, 11:51 PM Thread Starter
Tyler980
Suppose I'll have to invest in a welder soon and learn >.> Hopefully I can get the money for it before my frames too bad haha... at least its only the rear of the frame, the rest is solid.
Tyler980 is offline
