tranny skid/crossmember - JeepForum.com
post #1 of 31 Old 09-07-2013, 06:20 PM Thread Starter
Tyler980
I swapped my skidplate out with a new one but in the process I broke 3 of the 6 bolt inserts inside the frame... its held up by one bolt on driver side and two on passenger side. Is there anyway to bolt up the others without cutting into the frame?
Tyler980 is offline
post #2 of 31 Old 09-07-2013, 06:24 PM
NHfireLJ
NHfireLJ's Avatar
Nope... You could weld the skid to the frame... I did it temporarily until I could repair them right. You might be able to heat them and easy out the broken bolts, but they will probably spin, which means replacing the nutserts and new bolts
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #3 of 31 Old 09-07-2013, 06:31 PM Thread Starter
Tyler980
Well that's what I mean by what I broke. The nutserts broke... one I pulled out through the frame. The other I took a sawzall to lol
Tyler980 is offline
post #4 of 31 Old 09-07-2013, 06:32 PM Thread Starter
Tyler980
And one was missing when I bought jeep they had it slightly welded in that corner.
Tyler980 is offline
post #5 of 31 Old 09-07-2013, 06:34 PM
NHfireLJ
NHfireLJ's Avatar
Many have used theses... http://www.mcmaster.com/#weld-nuts/=oer4en but you need to weld it all up again and cut out the rotted steel..
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #6 of 31 Old 09-07-2013, 06:35 PM Thread Starter
Tyler980
That's my problem... no welder and no welding skill
Tyler980 is offline
post #7 of 31 Old 09-07-2013, 06:39 PM
NHfireLJ
NHfireLJ's Avatar
Are you a member of ENH.com?
Sign up, free. Exploring NH .com general 4 x 4 group. all makes, but a lot of fabbers on there and some in Rochester area.
I'm in Hampton if you get really stuck...
A guy has a shop in Hampton too and does good work relatively inexpensive
user name greatdivide
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #8 of 31 Old 09-07-2013, 06:41 PM Thread Starter
Tyler980
I'm not. I've been wondering if anyone from around here was on this forum . Well maybe after I get the jeep to stop ill see about getting it to someone.
Tyler980 is offline
post #9 of 31 Old 09-07-2013, 06:47 PM Thread Starter
Tyler980
Is it safe to say I should drive it around with lack of bolts on skid?
Tyler980 is offline
post #10 of 31 Old 09-07-2013, 06:49 PM
NHfireLJ
NHfireLJ's Avatar
I wouldn't w only 3...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #11 of 31 Old 09-07-2013, 06:53 PM Thread Starter
Tyler980
Would one of them like 120v welders be enough to weld it up a bit on each corner or something?
Tyler980 is offline
post #12 of 31 Old 09-07-2013, 06:59 PM
NHfireLJ
NHfireLJ's Avatar
Yup.
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #13 of 31 Old 09-07-2013, 07:03 PM Thread Starter
Tyler980
Maybe I will invest and teach myself . learned all my other wrenching abilities on this jeep.
Tyler980 is offline
post #14 of 31 Old 09-07-2013, 07:05 PM
NHfireLJ
NHfireLJ's Avatar
Not a bad way to go. I have a Lincoln 120V and did all my frame repair, and fabbed tire carrier etc... along with a crap load of other projects
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #15 of 31 Old 09-07-2013, 07:11 PM Thread Starter
Tyler980
Yeah my rear end of the frame is pretty rough. Maybe ill do that.
Tyler980 is offline
