Tranny noise - JeepForum.com
post #1 of 16 Old 08-26-2011, 11:28 AM Thread Starter
Sawicki4wd
Tranny noise
Well today my dad asked me to take his jeep for a spin because it was acting weird. It's an 90 yj with the 4.2. The tranny he said has been making an odd noise for a few months just didn't think anything of it. Now when I took it for a drive I noticed it's making a noise at idle in neutral but it stops when you push the clutch in. And its having a hard time going into gear. Have to pump the clutch to get it to go in. He had the clutch and slave changed maybe a year and a half ago so I'm leaning towards the pilot bearing. Am I right.
Sawicki4wd is offline
post #2 of 16 Old 08-26-2011, 12:39 PM
Newk76
If I remember what my husband had said ours was doing right, that's the same thing. We were having trouble w shifting between 3&4th, then he had some noise start as he left work one day. We've done a complete clutch replacement since it all came in the Luk kit. He was told it was the throwout bearing in our case.. of course, we haven't drove it yet so I don't know if that fixed the problem.
Newk76 is offline
post #3 of 16 Old 08-26-2011, 12:50 PM
cubewhiz
I'm thinking throwout bearing.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #4 of 16 Old 08-26-2011, 12:59 PM Thread Starter
Sawicki4wd
How hard is it to swap that out. I mean I did a tranny swap in my jeep buys it's the ax5
post #5 of 16 Old 08-26-2011, 01:51 PM
Newk76
ours has the ax15, my husband & a friend dropped the tranny & switched it out. Took the flywheel in to be resurfaced also while it was all apart. My husband had never done a clutch before, his friend has done a few but never in a jeep. I'd say if you've done a tranny drop before, shouldn't be too hard. One thing they learned the hard way, is that it's easier to put the transmission back up with the transfer case taken off, and it probably would have come out a lot easier that way also. There is a pretty good writeup about the ax15 drop somewhere on the forum, we used it for reference.
Newk76 is offline
post #6 of 16 Old 08-26-2011, 02:14 PM Thread Starter
Sawicki4wd
Well I did my ax5 and didn't drop the case. I just wanted one less thing that could go wrong. If it's just as simple I'll be happy
post #7 of 16 Old 08-26-2011, 02:17 PM
jhumphrey
Could be the pilot bearing. Did they replace that when they did the clutch a year or so ago? If they did, I'd be questioning what kit they used (or your dad is rough on clutches). Pilot bearings are cheap in price, but be sure to check everything while you have the tranny off. Personally, I'd put a new LuK clutch kit in while I had the tranny out. It may or may not be needed, but since its such a PITA to drop the tranny, fix everything you can so you dont have to keep doing it
jhumphrey is offline
post #8 of 16 Old 08-26-2011, 03:36 PM Thread Starter
Sawicki4wd
I'm not sure what they did exactly. I know they did a new slave and clutch. He's not looking to keep the jeep much longer. He bought a nice tj. And just kept the yj so he didnt put miles on his new car or his new truck or his newer jeep haha. He just figured I could fix it for him cheap.
post #9 of 16 Old 08-26-2011, 04:18 PM
jhumphrey
Well, depending on the shop, there's a 50/50 chance they changed the pilot bearing when they did the clutch. My LuK kit came with a newer (and nicer) bearing than what was in it. I'd say if you don't know, then change it and see what happens. Let's hope you get to it before it's caused damage to the clutch itself (unlikely, but anythings possible).
For me, changing the PB, is a PITA, just because you have to drop the T-case & tranny. I only do it when I have no other options and clean it all up while it's out because I hate to take it off anymore than needed. Others may disagree, but that's my .02 worth
"A woman's body is a work of art. A man's body is a utilitarian. It's for gettin' around. It's like a Jeep." - Elaine Benes
post #10 of 16 Old 08-26-2011, 06:10 PM Thread Starter
Sawicki4wd
Well I'll just change both of them. Which is which tho
post #11 of 16 Old 08-26-2011, 06:19 PM Thread Starter
Sawicki4wd
Well heres a new symptom. If I put it in first amd have my foot on the clutch it really doesn't want to roll forward. I had a friend push me and he had a real hard time doing it on a very flat road
post #12 of 16 Old 08-26-2011, 08:33 PM
jhumphrey
If the pilot bearing is shot, it'll keep you from fully engaging the clutch, which would explain why it was "stuck". Check out this article: http://www.novak-adapt.com/knowledge/clutches_etc.htm. It explains various clutch components.
I say change it all out since you have to drop everything. Better to be safe than sorry.
post #13 of 16 Old 08-26-2011, 08:40 PM
Quail
Yep, Throw out bearing.
You may want to bleed it just to make sure it is getting all the pressure it should before pulling the transmission back
Quail is offline
post #14 of 16 Old 08-26-2011, 10:46 PM Thread Starter
Sawicki4wd
Yeah I'll try bleeding it. It's not grinding so it's not to bad. And I guess my dad said they replaced all the bearings when then did the clutch
post #15 of 16 Old 08-27-2011, 06:43 AM
Quail
To be more acurate, I should have said the slave cylinder, but I think the bearing and slave cylinder are a one peice unit in the internal slave AX15s. Im not sure about that.
Quail is offline
