tranny mounts - JeepForum.com
post #1 of 6 Old 05-06-2002, 11:41 PM Thread Starter
ezgoing
ezgoing's Avatar
tranny mounts
What is the easiest way to check my transmision mounts to see if that is the reason for the dull thud when I depress or release the clutch while in any gear at any speed? It is really starting to get on my nerves. It doesn't happen when it is out of gear though or when I really ease the clutch in or out. The U-joints seem to be alright I did them just a few months ago. Is it possible it could be the output shaft, if so how do I check it?
Thanks in advance.
'92 YJ Sahara
1 1/4" shackle lift for now soon to be some sort of lift
31" Bridgestone Dueller A/Ts on AR-767 wheels
'67 Ford Galaxie 500 (passes everything but the gas station)
"What do you mean I can't make it, watch me!" = oops
ezgoing is offline
post #2 of 6 Old 05-06-2002, 11:56 PM
evilpsych
evilpsych's Avatar
sounds more like motor mounts are bad than tranny mount
get bombproof MORE's
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 6 Old 05-07-2002, 08:46 AM Thread Starter
ezgoing
ezgoing's Avatar
The dull thud seems to be coming from between the driver and passenger and just ahead slightly (if that made any sense). I'll be sure to check the motor mounts, um, how do I do that?
'92 YJ Sahara
ezgoing is offline
post #4 of 6 Old 05-09-2002, 01:41 PM
evilpsych
evilpsych's Avatar
on jeeps. the motor mounts are crap from the factory, best to just replace them altogether, either with new ones from autozone or bombproof ones from a performance shop.
i'm gettin a set of the 1" lift ones from MORE here shortly.
A
post #5 of 6 Old 05-09-2002, 06:24 PM Thread Starter
ezgoing
ezgoing's Avatar
Thanks evil, I'll add that to my list of things to do.
'92 YJ Sahara
ezgoing is offline
post #6 of 6 Old 05-09-2002, 06:38 PM
JeeperJay
I just ordered a engine/transmission mount kit from quadratec for just under $50. The dealer wanted $40 for just one engine mount!
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
Stripped a nut from one of the four tranny mounts. how do i get it off now???? Mitchin TJ Wrangler Technical Forum 21 02-10-2010 06:11 AM
tranny mounts wore down JVona TJ Wrangler Technical Forum 5 06-09-2009 01:47 PM
700r4 tranny mounts greatyanks23 YJ Wrangler Technical Forum 2 06-06-2007 12:55 PM
Tranny Mounts for 87(HELP!!!!) wwest76 YJ Wrangler Technical Forum 1 12-22-2006 11:20 PM
tranny mounts jeep98tj TJ Wrangler Technical Forum 17 05-31-2006 09:14 PM
