TRANNY HELP PLEASE!!!! - JeepForum.com
post #1 of 5 Old 06-03-2002, 05:08 PM Thread Starter
Chris C
OK,
Yesterday I dropped my belly pan on my '89 YJ to replace the Tranny mount. The old one practically crumbled in my fist. While doing this, we accidentally let the rear drive shaft slip out of its tube. We simply put it back together while jacking the tranny up and put everything back together with a new tranny mount. Here's the problem...My tranny used to be a little noisy, but since then, it has been a lot noisy. Where and how do I check fluids and so forth? Any help or suggestions are VERY appreciated. Sorry for the long post.
Chris C.
'89 YJ 4 Banger
1 1/2" Shackle Lift
30x9.5x15's on American Racing Nitro 15x8's
Custom Lock Box
Homemade Exaust
More stuff soon.
"I like it dirty"
Chris C is offline
post #2 of 5 Old 06-04-2002, 05:25 AM Thread Starter
Chris C
I said please. Anyone got an idea?
Chris C.
'89 YJ 4 Banger
1 1/2" Shackle Lift
Custom Lock Box
Homemade Exaust
More stuff soon.
"I like it dirty"
Chris C is offline
post #3 of 5 Old 06-04-2002, 11:12 AM
dasdaner
I believe the filler/check plug id up front passenger side. Good luck I hope it's the fluid. I'm changing my transmission this weekend.
88 yj 4cyl 2.5
dasdaner is offline
post #4 of 5 Old 06-04-2002, 11:32 AM
moabster
moabster's Avatar
2011 WK
The drive shaft could be un-balanced. I had a similar problem with datsun 510 (OK it was 20 years ago) after I changed the transmission. I put the drive shaft back turned 180 degrees from how I took it off. I got a terrible shake in in the drive train. I took it to a guy who balances drive shafts and he diagnosed the problem and fixed it in just a few minutes.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #5 of 5 Old 06-06-2002, 12:00 PM
lostboy
the driveshaft actually is from the back of the transfer case....there's a plug on the back of the case for draining and filling.....a chilton's manual would help here.
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
How do I Remove Shifter from Tranny? Tranny Brace Question as well kgillette YJ Wrangler Technical Forum 17 09-12-2010 07:11 AM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 07:10 AM
Should I repair Tranny seal or replace Tranny? Yankee-Juliet YJ Wrangler Technical Forum 10 03-29-2009 05:41 PM
tranny mount to tranny bolt size? pic inside dream911tommy YJ Wrangler Technical Forum 4 05-30-2008 09:16 AM
How much heavier is an auto tranny than the manual tranny? CB3 TJ Wrangler Technical Forum 9 12-24-2007 07:35 AM
