Tranny HELP!!! - JeepForum.com
post #1 of 5 Old 05-09-2002, 09:11 PM Thread Starter
clarky711
Tranny HELP!!!
OK, here we go, bear with me. I have a 94 sahara, with a 6 cly. and the AX-15 5 spd tranny. I have just bought the jeep about one and a half months ago with around 90,000 miles on it. The jeep runs great and used to have a real smooth transmission, untill about a week ago. It was stock untill i bought it, and the only thing i did was install a 3" Rough Country Lift with the transfer case 1.5 inch drop bracket. I did this about 3 weeks ago, and I felt the jeep drove better then stock. But, here is the problem, when downshifting from 4th to 3rd or 3rd to 2nd, it grinds like hell. Also, sometimes it won't even go into 3rd. I brought it to a tranny guy and he said it sounds like the syncro gears.@#@@?? He also said that a new tranny installed would be around 2 grand. Any opinions?? Thanks in advance. Oh yeah, the tranny fluid was thin and light brown, but i changed it(I know, water and oil) and the clutch is fine.?? What gives. Thanks.
01 Sport, 4.5" RE LA, 35" BFGs, 4.88 gears in Dana 44s, ARB up front, Eaton E-locker in back, Warn XD9000i, and a bunch of other goodies.....
Previously: 01 TJ on 32s, 94 YJ on 33s, 89 xj on 31s, 97 TJ on 31s, 79 CJ5 on 31s.
clarky711 is offline
post #2 of 5 Old 05-09-2002, 09:21 PM
jeepinarkansas
1982 CJ8
They recommend that you should trim the sheetmetal back around the stick shifter. I had mine heated and rebent to accommadate that issue with the same lift that u installed. I still have trouble getting into some gears after some city driving, and I think that It could be the syncros as well. 2 grand seems a lil high.
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #3 of 5 Old 05-09-2002, 09:26 PM Thread Starter
clarky711
I took both boots off the shifter and there was plenty of clearance for both the stick and the transfer case shifter. I also took the shifter off the transmission and the seals where fine. 2 grand was for a new tranny and the install. Oh boy. Thanks.
Mike
post #4 of 5 Old 05-09-2002, 09:27 PM Thread Starter
clarky711
Mike
post #5 of 5 Old 05-10-2002, 05:30 AM
runon4s
Sounds like you are not getting the clutch to ingage, Bleed the system & check on a leak. Sounds like you are loseing presure in the clutch master cylinder.
86 cj amc 304 bore 30 over, procomp cam, roller lifters, edelbrock intake and edelbrock shorty headers, holley carb, hmi distrib, Be cool raid, 2.5 procomp lift, 33x12.5x15 deep 10" Alum mag, dana 30f, 44r, tf999 auto with lokar shifter, 300 transfer, 8000lb winch, procomp bumpers, body rusted and abused.
runon4s is offline
How do I Remove Shifter from Tranny? Tranny Brace Question as well kgillette YJ Wrangler Technical Forum 17 09-12-2010 07:11 AM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 07:10 AM
Should I repair Tranny seal or replace Tranny? Yankee-Juliet YJ Wrangler Technical Forum 10 03-29-2009 05:41 PM
tranny mount to tranny bolt size? pic inside dream911tommy YJ Wrangler Technical Forum 4 05-30-2008 09:16 AM
How much heavier is an auto tranny than the manual tranny? CB3 TJ Wrangler Technical Forum 9 12-24-2007 07:35 AM
