tranny fluid - JeepForum.com
post #1 of 5 Old 09-16-2011, 07:31 PM Thread Starter
hemishot
tranny fluid
So last weekend I buried my Jeep to the bottom of the doors in mud(and found where all the missing floor plugs where!), since then my tranny, 5 speed, shifts hard for the first ten minutes of driving, but once the Jeep warms up, it shifts fine. Would a simple fluid change fix, or is it a more serious issue? Also, to change the fluid on the tranny, is it a simple drain and fill? Or is there more to it on these? Thanks!
hemishot is offline
post #2 of 5 Old 09-16-2011, 07:58 PM
I8AHUMR
Simple drain and fill.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #3 of 5 Old 09-16-2011, 07:59 PM
Old4X
1990 CJ7
It is a simple drain and fill. Use 10W-30 motor oil. May not be the cause of your hard shifting, but is a good maintenance item to do regularly.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 5 Old 09-16-2011, 08:13 PM
ejeeperguy
1982 CJ7
Well change the fluid and look for water in the fluid. If you got mud in it then you might have do a flush to get the dirt out.Even might have to open it up. The last thing is if youplan on doing that again change out all the vent lines to the tranny tcase and difs.They get old and crack water then can get in.
I would use the royal purple in the tranny .
ejeeperguy is offline
post #5 of 5 Old 09-18-2011, 01:21 PM
Brown Dog
Vendor
Brown Dog's Avatar
I've had great results with Redline. Remember, opinions on lubricants are like a certain body orifice...everybody has one.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
Tranny fluid leak between tranny and tcase doubleg TJ Wrangler Technical Forum 1 04-29-2011 04:37 PM
Need to change tranny fluid in my ax-15 soon any tips? fluid to use? Mitchin TJ Wrangler Technical Forum 37 07-04-2010 01:06 PM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 06:10 AM
What do you guys use to change the tranny fluid and xfer case fluid?? Wheelman TJ Wrangler Technical Forum 11 12-15-2004 03:33 PM
tranny fluid burrsy YJ Wrangler Technical Forum 2 10-31-2004 12:17 PM
