Tranny Donor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Tranny Donor
End of Summer Sale, 20% OFF!2007 - 2011 Jeep JK Long Arm Lift KitsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-25-2014, 06:22 PM   #1
vgilbertson
Tranny Donor
The 32RH in my 92 YJ is slipping. I found a 95 Cherokee Country that has 150K that has everything needed for swap but the guy is not sure if it is a AW4. Everything I have found says the Country is an XJ and should be an AW4. For 300.00 I can have the whole vehicle.
Any one know what tranny the Country came with?
Thanks
vgilbertson is offline   Reply With Quote
Unread 06-25-2014, 08:11 PM   #2
LilViper95
LilViper95's Avatar
Should be an aw4. It is a great swap and fairly simple. I used a 99 xj as my donor vehicle.
04 Ram 2500 5.9L 24v HO Cummins
My Attempt at a Wrangler YJ Unlimited
No Stretch TJ Build For The Wife
LilViper95 is offline   Reply With Quote
Unread 07-04-2014, 05:58 PM   #3
vgilbertson
The 95 did not work out but I found a 96 with 100K AW4 and NP231 Transfer case, has torque converter for 200.00. I picked it up today. The wiring harness has the pug ends, will need to go to the junk yard to find a TCU with plug and a shifter.
The AW4 does not have a flex plate - Do I need to purchase one or will the 32RH work?
