tranny - JeepForum.com
post #1 of 3 Old 11-11-2001, 04:01 PM Thread Starter
jeep thing
tranny
I have a 92 yj when i put it in 4 low the gear shifter moves about 4inches. It does it in forward and reverse. I seems to do it when it is in a lot of mud or when it is towing something. Need a little help i dont think it could be good for it.
jeep thing is offline
post #2 of 3 Old 11-11-2001, 05:02 PM
bob91yj
I'm not real clear on how it moves, but I'd take a look at your motor mounts and your tranny mounts for starters.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #3 of 3 Old 11-12-2001, 03:37 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Wish you gave a little more information .. the '92 YJ's had many different options, including different engines and trannys .. all of the transfer cases were the same between the different models.
Now, when you say it moves, which direction? Only when you use 4low? Is it the transmission shifter that moves, the tcase shifter that moves, or both of them together?
Also .. where in Canada are you?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
How do I Remove Shifter from Tranny? Tranny Brace Question as well kgillette YJ Wrangler Technical Forum 17 09-12-2010 06:11 AM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 06:10 AM
Should I repair Tranny seal or replace Tranny? Yankee-Juliet YJ Wrangler Technical Forum 10 03-29-2009 04:41 PM
tranny mount to tranny bolt size? pic inside dream911tommy YJ Wrangler Technical Forum 4 05-30-2008 08:16 AM
How much heavier is an auto tranny than the manual tranny? CB3 TJ Wrangler Technical Forum 9 12-24-2007 06:35 AM
