Tranfercase Question! - JeepForum.com
post #1 of 8 Old 11-10-2013, 05:03 PM Thread Starter
Guns003
So the PO of my jeep replaced the 231 in my 95' to rebuild it. He put a cherokee tranfercase in it as a replacement. I was going to put a SYE conversion on the rebuilt one and swap it out. But the cherokee 231 works really well and i noticed it has a CV joint? Is it essentially the same as a SYE kit? So i wouldnt need one when i do my lift? Only a driveshaft right?
1995 YJ
35" Procomp MT2s, 5.5 inches of lift, RE 4.5 XD, Bilsteins, MORE body lift, Bumpers,TJ flat fender flares, HD steering, Durango steering box, ZJ 136amp alt, Ford 8.8 Rear, 4.56s
Guns003 is offline
post #2 of 8 Old 11-10-2013, 07:03 PM
AmmitOsiris
AmmitOsiris's Avatar
Pictures are worth a thousand words Sent from Peggy's office
AmmitOsiris is offline
post #3 of 8 Old 11-10-2013, 07:08 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Cherokee uses CV on front driveshaft, not on rear.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 8 Old 11-11-2013, 10:33 AM Thread Starter
Guns003
Ok so i just got pictures! Looks like a cv joint to me but i really have no experience? Havent seen a slip yoke with out the boot so maybe thats what it is?
1995 YJ
Guns003 is offline
post #5 of 8 Old 11-11-2013, 10:43 AM
AmmitOsiris
That is a slip yoke. It needs a sye.
post #6 of 8 Old 11-11-2013, 10:44 AM
kloppk
Whatcha have there is the stock single U-Joint setup... not a "CV" which has 2 u-joints.
Here is a "CV" joint.
(Technically it's not a CV joint, it's actually a double cardan joint but is frequently referred to as a CV joint)
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #7 of 8 Old 11-11-2013, 10:49 AM Thread Starter
Guns003
Ah ****! Thought i was gonna save a buck!
1995 YJ
Guns003 is offline
post #8 of 8 Old 11-11-2013, 11:56 AM
xeroid81
FSJ's with the quadratrac system used a double cardin up front because it was full time 4wd. Hence the term constsant velocity or CV joint. It is A CV joint in that respect.
xeroid81 is offline
