Quantcast Trailmaster lifts? *Need opinion* - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Trailmaster lifts? *Need opinion*
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 12-17-2004, 11:35 PM   #1
BeatAChevy289
I just put in an order for a 2" Trailmaster suspension lift and I was wondering if anyone has used one before. I know they make body lifts too but I already have one, so anywho. Anyone have an opinion? I tried to search it and only got one link but it didn't have enough detail for my liking. Later <><
1995 Firebird Formula, 6-speed, LT1 V8, t-tops, open exhaust. **In the For Sale section***
1966 Ford Mustang, Hi-Po 289 V8, 4:11's, I dare you to race me.
[URL=http://www.cardomain.com/id/blackyj95]Cardomain Site[/URL] (different from the other link)
BeatAChevy289 is offline   Reply With Quote
Old 12-18-2004, 01:22 PM   #2
micfly83
I bought mine used with a 3" trailmaster on it, and the thing rode pretty stiff. I swapped out all the shocks for some DT3000s and removed the smallest leaf from each pack. This helped out a lot and it allowed my Jeep to ride like a YJ and not a tank. I'm not so sure about the 2" lift, the springs wont be as arched so it may ride fine. As far as flex, its not great and its not bad. I haven't had a chance to test my flex out with the spring removed, but I've heard its really good.
BTW my trailmaster shocks were really screwed up when I put in the DT3000s. The front ones would hardly compress at all and the rear ones would compress incredibly easily.
1994 Jeep Wrangler YJ, 2.5L High Output, High flow aluminum intake, 4.0L Throttle Body, 62mm TB Spacer, bored out intake manifold, 5spd, 3" suspension lift, 31" BFG A/Ts, Two 10,000lb tow hooks, DT3000s, Outland lightbar, 5 high powered offroad lights, Mapp Nerf Bars, 102" whip antenna, Midland CB, 6 speaker soundbar, Smallest leaf removed, Air restrictor removed, No trackbars, No swaybars, No A/C, Custom 32 song horn-
http://www.cardomain.com/memberpage/753987
micfly83 is offline   Reply With Quote
Old 12-18-2004, 01:25 PM   #3
micfly83
Stiff lifts are a common topic at jeepsunlimited.com, so you might wanna check them out to get some more opinions.
Old 12-18-2004, 02:35 PM   #4
BeatAChevy289
Thanks, I may do that. Thanks for the info though. For the price it cost, I couldn't pass it up. Later <><
Glock Forum
