Trailmaster 3in lift w/Bilstein 5100 shocks - JeepForum.com
post #1 of 10 Old 10-04-2011, 12:36 AM Thread Starter
BIGJoe29
i was wondering on getting a 3in lift without shocks on a yj and i was wondering wat would b the best choice. my limit is around 900. i will be buying Bilstein 5100 shocks because i have heard good things about them. any recommendations will be helpful. the sites i can get them off of wuld be helpful too. i will b getting 15x7in rims on 31x10.5 or 31x12.5 tires with 1in wheel spacers if that helps.
BIGJoe29 is offline
post #2 of 10 Old 10-04-2011, 12:45 AM
Jakes89Wrangler
12.5 inch tires are to wide for 7 inch rims, minimum is 8 to be safe. Buying different rims with the right backspacing would solve your wheel spacer problem.
Jakes89Wrangler is offline
post #3 of 10 Old 10-04-2011, 06:52 PM Thread Starter
BIGJoe29
thnx. i was mainly inquiring on the lift and shocks. do you have an opinion on those?
BIGJoe29 is offline
post #4 of 10 Old 10-04-2011, 07:33 PM
yjgrillin
I have 31'' bfg a/t's on mine stock, I feel like a 3.5'' lift would be overkill for 31's. I only hit the fenders at full flex and only at full lock when turning- stock wheels with their ungodly backspacing. If you really want the lift, I'd say look for 33s, or stay stock and run the 31s until you can do everything at once.
yjgrillin is offline
post #5 of 10 Old 10-04-2011, 09:38 PM Thread Starter
BIGJoe29
its just a 3in lift. i kno 3.5in lift wuld b WAY overkill
BIGJoe29 is offline
post #6 of 10 Old 10-04-2011, 10:34 PM
jhumphrey
Im just going to put this out here, but a 3" lift on 31x10.5's is overkill too. You're going to have a ton of space between the top of your tire and the bottom of your fender. You wont have to worry about rubbing at full flex, that's for sure, but for aesthetic reasons, 3" lift with those tires are not going to look that great, just FYI. Trust me, the PO of mine put a 3" or so body lift on my jeep. I dislike it very much and plan to do a 2" suspension lift ASAP.
If your rim is going to be 15x7, do not get the 31x12.5's, it wont work. Also, buying a 5100 series bilstein for a 31" tire is a waste of money. You can outfit your entire jeep with, say, Monroe's, for the price of one of those. Unless you were going larger (33" max, according to bilstein), there is absolutely no reason to get those. 31" tires arent that much larger than stock tires, so buy a good shock, but dont waste your hard earned cash on overkilled shocks. Trust me, I have 31x10.5's on my jeep. I will be going to a 33 or 35 in the future...Ive done a lot of research on shocks, lifts, etc.
Plus, as a side note, if you go 3" or more, you may need to do a lot of other work to your jeep (tcase drop, sye/cv drivshaft, drop pitman arm, etc). You'll need all the extra cash you can get...its the little things that get you when you start wanting to lift over 2.5".
jhumphrey is offline
post #7 of 10 Old 10-05-2011, 08:39 PM Thread Starter
BIGJoe29
so if i get a 2.5 in lift i wont have to add any of the extra parts u mentioned?
BIGJoe29 is offline
post #8 of 10 Old 10-05-2011, 10:40 PM Thread Starter
BIGJoe29
now i took your advice and i was wondering what would be better a Rubicon Express 2.5" Standard Suspension System with Twin Tube Shocks or an Old Man Emu 2.5" Suspension System?
BIGJoe29 is offline
post #9 of 10 Old 10-05-2011, 10:45 PM Thread Starter
BIGJoe29
or a Pro Comp Stage I 2.5" Suspension Lift Kit?
BIGJoe29 is offline
post #10 of 10 Old 10-05-2011, 10:57 PM
jhumphrey
No, usually 2.5" or less and you don't have to do any of that stuff. I have heard that rubicon express is good. I've also heard good things about old man emu. Personally, I plan to buy my lift components from BDS suspensions. It's also advisable to piece it together rather than buy a kit. Retailers charge a ton for their kits...more than they should really.
"A woman's body is a work of art. A man's body is a utilitarian. It's for gettin' around. It's like a Jeep." - Elaine Benes
jeep , shock , suspension lift , wrangler , YJ
OME vs Bilstein 5100 shocks? TJoshX TJ Wrangler Technical Forum 11 04-14-2011 10:41 PM
Bilstein 5100 shocks on a stock JK? DIRTYDISHES JK Wrangler Technical Forum 0 03-31-2010 09:36 PM
BDS Shocks vs Bilstein 5100 / 5150 drandersoninc TJ Wrangler Technical Forum 9 01-20-2010 12:16 PM
Bilstein 5100 or FT shocks? Ejunior2 TJ Wrangler Technical Forum 2 05-31-2008 05:11 AM
Bilstein 5100 shocks - part #s beachtaco TJ Wrangler Technical Forum 2 03-30-2005 01:04 PM
