#1 | |
traction bar dimensions
anyone that has a m.o.r.e traction bar could you measure from the center of each bushing and give me some dimensions i would appreciate it. they dont have to be perfect
1995 YJ Rio Grand - work in progress |
#2 |
Free clues & suggestions
Okay, since nobody else chimed-in....I'll head to the garage (stoping by the refrigerator first to grab a beer or two
) then crawl under my POS & take a few measurements for ya'.After a few beers, the measurements are likely not going to be perfect. ![]() |
#3 |
From center zerk to center zerk of the axle tube lower & upper bushing bolts = 6.5"
From the axle tube lower zerk to the johnny joint bolt center = 29 7/8" From the axle tube upper zerk to the johnny joint bolt center = 28 7/8" The shackle bolts center to center = 4" One very important thing to remember is that the MORE TB is adjustable. Mine is adjusted all the way in. So, in other words, the upper measurement could be longer if my pinion angle was not as steep, plus the manner you attach it to a crossmember also effects this measurement. The goal is for when it sits statically, the shackle sits 90* perpendicular to an imaginary line between the upper & lower traction bar tubes. |
#4 |
alright thanks that is very helpful
#5 | |
#6 | |
Do you have a picture of what you are describing above? I have a Sams offroad bar, but it is the old one that is not adjustable. I have a custom built crossmember that it will mount to. I think I see what you are saying, but a picture would help. Sorry for the hijack. Thanks, Jared
1995 YJ 4.0L automatic SOA on 1.5" Superlifts 35" BFG A/T's on AR 767's D30/8.8 4.56 gearing
#7 | |
#8 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
