TPS voltage ... supply is showing .4 lower than it should - JeepForum.com
post #1 of 1 Old 10-20-2007, 08:33 PM Thread Starter
intenseblu
1987 YJ Wrangler
heya guys i finally got my rig driving around but i started a new job and am working about 14+ hours with commute included so that leaves no time to do real proper troubleshooting at the moment ...
however today i had a hour free i pulled out the ol voltage meter and tested the TPS just as the manual describes ... the first part of the test they tell you put it at a wire with the key in run mode and see the voltage. this is testing the TPS voltage supply wire as they want it to show 5 volts ... to my shock it shows 4.6 so either the wire is corroded all along and there is a resistance drop or the computer is not supplying the proper voltage due to a weakened and sure to fail one day voltage regulator within.
my question
... anyone ever see this happen and find it to be the computer that is the issue not the wiring ?
i am going to test the wire path as soon as i get a few hours free in a week or so but hopefully someone that has had this issue come up as well will chime in with some been there done that wisdom.
intenseblu is offline
reasons my passenger side is dropping lower...and lower...?!? damuddmann TJ Wrangler Technical Forum 8 12-20-2009 09:46 PM
Drivetrain lift+flat belly+lower suspension=Lower COG doug_1994 YJ Wrangler Technical Forum 21 09-12-2009 07:19 AM
No Spark but coil has voltage at supply bsousa YJ Wrangler Technical Forum 2 06-12-2008 04:51 PM
Voltage Guage low but voltage ok keithert TJ Wrangler Technical Forum 8 02-27-2008 11:14 AM
Does a low battery voltage mean a low running voltage? ElvisV04290 YJ Wrangler Technical Forum 4 04-10-2007 06:02 PM
