tps question - Page 3 - JeepForum.com
post #31 of 77 Old 08-21-2013, 12:52 PM Thread Starter
hotcobra03
hotcobra03 is offline
post #32 of 77 Old 08-21-2013, 12:56 PM
Que89YJ
Can't see pics at work. Whats the pic of?
Que89YJ is offline
post #33 of 77 Old 08-21-2013, 01:27 PM Thread Starter
hotcobra03
timing chain,,if im seeing it right its 180 out..
engine is at tdc 0 .on compression stroke.rotor at number 1'
pic shows dot at top of gear on cam,bottom is key way at 12 oclock
post #34 of 77 Old 08-21-2013, 01:29 PM Thread Starter
hotcobra03
its inline with bottom,,
if so how should I change it,,my cobra is an interference engine
post #35 of 77 Old 08-21-2013, 02:28 PM
Que89YJ
In the forum that has come up. Do a search.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #36 of 77 Old 08-21-2013, 05:46 PM Thread Starter
hotcobra03
I did google,,its back together,started at crack of key, idle 750''
going now for test drive to fuel station,
post #37 of 77 Old 08-21-2013, 05:49 PM Thread Starter
hotcobra03
I undid chain,,with dizzy out,turned cam,lined up dots.turned over couple times by hand,,set dot on cam to 3 oclock area.counted pins to crank..got 20'
re installed dizzy on 0 of compression stroke..
post #38 of 77 Old 08-21-2013, 06:52 PM Thread Starter
hotcobra03
back from spin,,it drove nice but still dead..this time lrsd spit spudder,,
pulled over un plugged ait sensor,,took more power away rigjt from idle..
re hooked,un plugged coolant sensor,,wow hit 70 mph
guess Im getting closer, let me locate sensor
post #39 of 77 Old 08-22-2013, 07:25 AM
Que89YJ
Use a meter and start checking. I hate throwing parts at it. Temp sensor seems like a good call though! You need to go through the adjustments. It isn't the same critter as the OBD 1 Jeep. You need to baseline the sensors so the ecu has a good refrence for each. The temp sensor has a resistance chart in the manual to check it's function. Glad to hear its running.
Que89YJ is offline
post #40 of 77 Old 08-22-2013, 10:09 AM Thread Starter
hotcobra03
I ordered new sensor,20 bucks
I did ohm sensor..i have no manual on how to read meter
it shows 3 ranges and is automatic..
range scale is 4'40'400
im getting 2.8 on a 4 scale
when I did plug wires they were 2.3 new was 6 7 on a 4 scale
post #41 of 77 Old 08-22-2013, 10:15 AM
Que89YJ
It's setting more then just a scale. You need to set it to the correct mode. The manual might help but you should have a selecotr switch to read voltage ac, voltage dc, current, and resistance. You need t set it up first then select the scale. The readings on the scale must be higher then the expected reading when you set the range. You tube has some video's and if you can look up the brand on line and find the manual I can help you set it correctly.
Que89YJ is offline
post #42 of 77 Old 08-22-2013, 10:49 AM Thread Starter
hotcobra03
im going to try the setting u linked.my pc is down so on cell,its hard to read being tiny page..
I went and started engine,,let it warm..
I got,36.5 on 40scale on ait
I got 26.5 on coolant on 40 scale
I got 250. 5 on 400 scale on temp sensor
250 on oul pressure sender on 400 scale..with numbers changing to revs
post #43 of 77 Old 08-22-2013, 11:46 AM
Que89YJ
You can measure resistance with voltage present/vehicle running. Volt meters use their internal battery to power the circuit you are testing when you measure resistance. Sening you a pm with my number. Call me.
Que89YJ is offline
post #44 of 77 Old 08-24-2013, 03:54 AM Thread Starter
hotcobra03
Ok heres where im at..
Got new coolant sensor..I tested it vs old..
Old was good..
I retested iat sensor..this read different..I also found it changed as I moved it..
I took old coolant sensor and wired that to iat..
Wow things changed..isa motor freaked out clicking ..the plunger would jump but towards closed throttle..
Took for a ride..it now is driveable vs before..I will get ait sensor
It got up to 65 in 3rd..4th half throttle was best held 50 got 60 with 3quarter pedal..
Wot it bogged..5th bogged..
I know its timing advance and fuel..
The speed sensor I haven't touched yet..
Im also at 4000 ft above sea level..so thought that might another issue to a point
post #45 of 77 Old 08-24-2013, 06:07 AM
XJ93
Okay, IAT does mess with air/fuel ratio, why do you want to mess with speed sensor?
XJ93 is offline
