TPS Maybe? - Page 4 - JeepForum.com
post #46 of 60 Old 08-23-2013, 11:57 AM
XJ93
Sounds like some transmission work is needed. The clutch would slip in any gear not just the higher gears. You may have broken gears in the trans. It's a manual so a lot simpler than automatics, open her up and take a look.
XJ93 is offline
post #47 of 60 Old 08-23-2013, 11:58 AM
Siva283
This is my thought but some disagree. Which I am fine with I would just like to know why it would be different for different gears since all the clutch does is mechanically connect the engine to the trans regaurdless of gear.
Ask me how I know...
Siva283 is offline
post #48 of 60 Old 08-23-2013, 12:07 PM
XJ93
Different gears is the key, same clutch so take it out of the equation. The clutch will act the same regardless of what gear you are in. If you look at an exploded diagram of any manual transmission you will see several different gears "stacked" together. When you move the shifter into a different position you are engaging different gears. I had a Firebird in which 4th gear was out. All the other gears worked great. When I finally took the transmission apart there were several teeth broken off the fourth gear.
XJ93 is offline
post #49 of 60 Old 08-23-2013, 12:59 PM
Siva283
I agree with this conclusion. The clutch engauges the same regaurdless of gear. What it sounds like happened is the bearings on the main shaft or counter shaft inside the trans are gone. It gives just enough play for the gears to not engauge. It explain some gears not working(The bearings at one end went) and then none working(the bearings at the other end went) Have you ever got water in the trans OP.
Siva283 is offline
post #50 of 60 Old 08-23-2013, 01:41 PM Thread Starter
scraper
Well I'm well into the Tran removal. One quick question. Do I remove the exterior clutch cylinder attached to the Trans or undue the line coming from the upper fill reservoir that attaches to that exterior cylinder (sorry I'm not sure which one is called the slave and the master)?
scraper is offline
post #51 of 60 Old 08-23-2013, 01:43 PM Thread Starter
scraper
My neighbor (same guy who helped me push the jeep into the garage today) claims he knows how to rebuild a Trans. So I'm going to have him look at it while it's out and I will replace the clutch regardless, but I will also replace anything else that looks out of sorts. I will also post pics here so you guys can look at it and tell me what you think.
scraper is offline
post #52 of 60 Old 08-23-2013, 01:46 PM
Siva283
Be carful of people that claim they know how to do this. Play dumb and ask questions anout it to see what he really knows
Sent from my SPH-L300 using JeepForum
Siva283 is offline
post #53 of 60 Old 08-23-2013, 02:43 PM Thread Starter
scraper
Here's the first casualty. I snapped the Shifter knob while trying to wrench it off. That sucker was STUCK. Oh well if that's all that goes wrong I will be in good shape.
scraper is offline
post #54 of 60 Old 08-23-2013, 04:37 PM Thread Starter
scraper
Well I don't have it all the way down yet, but just looking at what is behind the plate, it looks like a Mouse decided to make the bellhouse its home. There is also some mouse packing back where the Slave Cylinder goes into it, so I can only imagine the extent of the mouse damage at this point. Heres a pic:
scraper is offline
post #55 of 60 Old 08-23-2013, 06:19 PM Thread Starter
scraper
More pics:
You can see the mouse packings in there.
More mouse packing in the clutch teeth:
scraper is offline
post #56 of 60 Old 08-23-2013, 07:24 PM
Que89YJ
That's incredible!
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #57 of 60 Old 08-23-2013, 07:27 PM
ktw23
Bet that mouse got nice and warm in there
2002 TJ 4.0, 4" Pro Comp on 33x12.50's 3.73's D30 & D44 - Daily Driver
1995 YJ 4.0, 4" Rough Country on 33x12.50's 3.07's D30 & D35 - SOLD
1994 ZJ 5.9 Laredo - SOLD
Just Empty Every Pocket
ktw23 is offline
post #58 of 60 Old 08-25-2013, 09:58 AM Thread Starter
scraper
Here is the old clutch taken apart. You can't really tell from the picture, but the teeth on the clutch wheel are flat, whereas on the new one they stick up a good bit.
The flywheel is actually in good shape, but It's only $40 for a new one using the Advanced Auto 40% code so I'm gonna replace it.
scraper is offline
post #59 of 60 Old 08-28-2013, 06:47 PM Thread Starter
scraper
Just an update. It was the clutch. The jeep now runs fine in all gears. My guess is that at first it ran in 1st and 2nd because there is less friction needed to make the clutch engage in those gears, but once it got up to higher speeds it couldn't catch anymore.
scraper is offline
post #60 of 60 Old 08-28-2013, 06:48 PM
bigbossd1030
Perfect example of it not always being the expensive stuff! Right on, great to hear!
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
