TPS Maybe? - Page 2 - JeepForum.com
post #16 of 60 Old 08-20-2013, 05:00 PM
Siva283
Originally Posted by XJ93 View Post
Good catch Siva
Thanks. Unfortunately that's all I have to offer at the moment.
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #17 of 60 Old 08-20-2013, 06:42 PM
bigbossd1030
Good catch Siva
Indeed good catch!
That can explain a lot of his issues!
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #18 of 60 Old 08-20-2013, 07:33 PM Thread Starter
scraper
The next logical question is how much would you expect this to cost if I took it to a local garage and it really is the clutch? I don't think I really want to pull the tranny myself and then figure out whats wrong.
scraper is offline
post #19 of 60 Old 08-20-2013, 07:34 PM
Siva283
That number varies greatly depending on the place.
Siva283 is offline
post #20 of 60 Old 08-20-2013, 07:41 PM
bigbossd1030
They wanted 800+ parts here to do mine. But all places are different. That was the dealer here, in spruce grove.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #21 of 60 Old 08-20-2013, 07:58 PM
Siva283
I have seen as cheap as 350 $ and as much as 1200 $. If its not a dd its not hard to drop the trans. Just time consuming. I can drop mine replace the clutch and put it back in about 6 hours. That was the first time I ever dropped one. If you were near me I would gladly help you do it
Siva283 is offline
post #22 of 60 Old 08-21-2013, 08:34 AM Thread Starter
scraper
That would be cool, I actually live about 30 minutes from the West Virginia border, but you are on the wrong side of the mountains. Oh well, I may just take it to a local shop that I know is trustworthy and see what they come back with.
scraper is offline
post #23 of 60 Old 08-21-2013, 01:51 PM
hotcobra03
open this has free tsbs and wiring diagrams
http://www.bbbind.com/tech_database.html
im working on 89 2.5. both tsbs for me seem to be my issues..
intake gasket was just done,but it looks like valve timing is out..
there were only 2 for this engine..
hotcobra03 is offline
post #24 of 60 Old 08-21-2013, 05:27 PM
Siva283
I am actually in frederick md. Where are you at? Cumberland. Sorry I can't see that info on the mobile app that I use 99% of tge time
Siva283 is offline
post #25 of 60 Old 08-21-2013, 08:01 PM Thread Starter
scraper
I'm in Minerva Ohio which is a tiny bit closer to Pittsburgh than it is to Cleveland. I actually have to travel through the Northern Arm of WV to get to Pittsburgh.
scraper is offline
post #26 of 60 Old 08-22-2013, 05:34 AM
Siva283
Gotcha. Thats a bit of a hike
Siva283 is offline
post #27 of 60 Old 08-22-2013, 08:12 AM Thread Starter
scraper
At this point all signs tell me the clutch is slipping in 3rd, 4th, and probably 5th gear and I'm seriously thinking about fixing it myself.
BUT, is this something that a new clutch kit will solve, or is there something more to it. Also does anyone know of a good write up for an AX 5 showing the steps? I know how to get the Transmission out, its the steps after that that I need help with.
If people can reasonably do this in 6 or 7 hours then I figure it should only take me about 14.
scraper is offline
post #28 of 60 Old 08-22-2013, 08:22 AM
Que89YJ
http://www.jeepforum.com/forum/f12/a...p-pics-505640/
http://www.jeepforum.com/forum/f12/a...-pics-1041722/
You might want to look at the Dakota bellhousing and popping in an AX 15 if you are interested in a mod and getting rid of the AX 5.
Que89YJ is online now
post #29 of 60 Old 08-22-2013, 03:05 PM
Siva283
The clutch should slip in all gears if it is worn. Not just fourth and 5th. I am thinking you may have a trans issue. A quick test. Start it put it in fourth and try to take off. See if it stalls.
Siva283 is offline
post #30 of 60 Old 08-22-2013, 04:02 PM Thread Starter
scraper
Tried this. Jeep doesn't stall. It just acts like it's in Neutral still.
scraper is offline
