TPS confusion - Page 2 - JeepForum.com
post #16 of 21 Old 08-28-2013, 08:41 PM Thread Starter
DTR
Originally Posted by DTR
I can't find a leak...been spaying carb cleaner but not noticing any change in the engine. I did not change the tb gasket the original is like a sticker and looks good.
Sorry... Changed the iac sensor
DTR is offline
post #17 of 21 Old 08-28-2013, 09:27 PM
Que89YJ
The idle went high after the iac was changed and they're isn't any vacuum leak then I think I know what is wrong. There are after market iacs that have an adjustable pindle length. I think yours is too short and needs to be adjusted out.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #18 of 21 Old 08-28-2013, 09:38 PM Thread Starter
DTR
How do you adjust?
DTR is offline
post #19 of 21 Old 08-29-2013, 04:39 PM
Que89YJ
Adjust them by turning them. I have never done it. The oems are set but I am sure if you Google it you will find it. Some of them are adjustable and others will break if you try to spin the it so please check. Everything seems to point to the iac.
Fault codes:
No Start:
Que89YJ is offline
post #20 of 21 Old 08-29-2013, 07:10 PM Thread Starter
DTR
Figured out the problem, turns out I installed the gasket in the IAC housing backwards. Chalk this one up to not paying attention when reassembling the throttle body.
Seems to be idling pretty good around 1000 hopefully it will settle around 800 after I drive it some more.
Thanks again for all the help, I really have been enjoying working on the jeep myself rather than bringing into a mechanic.
DTR is offline
post #21 of 21 Old 08-29-2013, 09:31 PM
Que89YJ
Glad to hear it. Do the battery reset.
Fault codes:
No Start:
Que89YJ is offline
