-   -   TPS confusion (http://www.jeepforum.com/forum/f12/tps-confusion-1566573/)
DTR 08-24-2013 03:57 PM
TPS confusion
Hi,
I am getting a high idle (2k) after I cleaned TB today. I removed the IAC and TPS when I cleaned the TB...put it all back together but its running fast and smells a little rich.
Any advice out there?
1993 2.5l manual
:confused:
Que89YJ 08-24-2013 05:18 PM
Check to see if you have fault codes. Running high idle is a vacuum leak. Spray around with brake/carb cleaner A's listen for an idle change. Do a battery disconnect for a 10 count to reset calibration.
DTR 08-24-2013 06:04 PM
I dont see any air leaks and have completed the battery restart. After driving around the idle settles in at 1500.
Would the IAC or TPS cause a high idle?...seems to be running just fine otherwise.
...and no engine codes today
thanks for the help
Que89YJ 08-24-2013 06:44 PM
Yes. The Iac sets idle. The tps is an input to the ECU for throttle position for setting advance. It sounds like the iac is messing up. I would still spray around and see if you hear any idle change A's check the vacuum lines. Maybe the pcv on the top of the valve cover.
DTR 08-24-2013 06:45 PM
What about the small screw under the throttle cable...can this be adjusted. Mine shows a little bit of some factory paint on the threads, I wonder if this was adjusted by the PO.
Que89YJ 08-24-2013 06:52 PM
That is locktite and the throttle is controlled by the ECU. Did you have a high idle before you cleaned the throttle body and iac?
DTR 08-24-2013 07:01 PM
my idle speed was always low and seemed to miss sometimes...around 450 rpms
Que89YJ 08-24-2013 08:11 PM
And now it's high. If you played with the iac and it is staying high then your iac is probably shot.
Firefyter-Emt 08-28-2013 08:57 AM
95 Attachment(s)
Disconnect the ground cable and touch it to the positive cable. That will reset the CPU. If you still have a high idle, BUT the idle drops, just not low enough.... Try replacing the coolant temp sensor at the water neck (apx $20.00).
I fought this for a while swapping around TB's and IAC's before I replaced that sensor. My temp gauge worked so good that I was even able to see a ten degree decrease when I overhauled the cooling system, and it remains unchanged, but it fixed my high idle issue.
Mine would run at 1600 and drop to 1200. A CPU reset would fix it for a week, then a few days, then one drive cycle. When reset, it would be at 1100 and drop to about 600. Drive me nuts, but the coolant temp sensor did the trick for me!
Luuca 08-28-2013 04:38 PM
What is the proper idle RPM? I believe my 2.5l idles around 700-800 rpm. I'm nearly 100% positive that 1000 rpm is high. Que? :confused:
Que89YJ 08-28-2013 06:59 PM
It is a little high. 700/800 it's normal but 1000 isn't terrible.
DTR 08-28-2013 07:17 PM
Well i put in a new iac sensor and reset the computer but still getting a high idle (2k)...drove it around to see if it would reset the idle...nothing changed.
Runs great just idling really high...any ideas? what else can i test?
thanks for the advice!
Que89YJ 08-28-2013 07:31 PM
Which sensor? If it was running low before you messed with the throttle body A's now it's high you problem is in the throttle body I still think you have a vacuum leak
DTR 08-28-2013 07:32 PM
Was your coolant sensor working before u replaced it...your gauge showed ok?
DTR 08-28-2013 07:39 PM
I can't find a leak...been spaying carb cleaner but not noticing any change in the engine. I did not change the tb gasket the original is like a sticker and looks good.
The time now is 07:38 AM.
