Tow/recovery hook installation write-up - JeepForum.com
 1Likes
post #1 of 29 Old 10-04-2009, 05:13 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Okay, so I had no tow/recovery hooks on the front of my '91 YJ, so anytime I got stuck it was a pain to find a decent place to hook up a strap. The other day I bought 2 of these Reese brand tow hooks from Tractor Supply Company for $11.99 each. They're rated at 10,000 lbs. each, so I figure I'll have to be stuck really bad in order to break them!
They came with this 1/2" grade 5 hardware, so I upgraded to 1/2" grade 8 hardware when I installed them. The factory bumper bolts are #55 Torx fasteners with 1/2 threads.
I bolted them up to the factory bumper bolt location, and this put the 2nd bolt directly above the pipe shaped front crossmember.
I used the hole in the tow hook as a drill guide & drilled a 1/2" hole through the frame rail and pipe. I then used the new grade 8 hardware to install them. I put a 1/2" flat washer between the tow hook's rearward hole & frame to act as a shim. This allowed it to sit flush with the bumper.
I also used flat washers under the bolt heads for a more "finished" look.
Now I'm ready to get stuck!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 29 Old 10-04-2009, 05:36 PM
Tompatt
1987 YJ Wrangler
nice write-up.. dude u got TOO much time on your hands. haha.
Thomas
-1987 YJ
Tompatt is offline
post #3 of 29 Old 10-04-2009, 06:09 PM
pasinbuy
Whatever!
Very cool write up. Good idea for a emergency. Thanks
pasinbuy is offline
post #4 of 29 Old 10-04-2009, 07:23 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Dude, get some new bumpers
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 29 Old 10-04-2009, 08:18 PM
Tompatt
1987 YJ Wrangler
why? ha.
Thomas
-1987 YJ
Tompatt is offline
post #6 of 29 Old 10-05-2009, 08:39 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Hi Max
Very nice job!
Where did u buy those hooks? I'd like to do this on mine...
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #7 of 29 Old 10-05-2009, 09:21 AM
Plato2k5
now you just need some hooks on the back.
Take two and put them in the receiver with a bolt. Works awesome!!
Plato2k5 is offline
post #8 of 29 Old 10-05-2009, 09:25 AM
jbolty
jbolty's Avatar
I'm confused. Every YJ I have ever seen already has two threaded holes on each side for the hooks, even if it did not come with any.
FYI. late model chevy and gmc pickup tow hooks have the same bolt pattern.
jbolty is offline
post #9 of 29 Old 10-05-2009, 10:27 AM
bigh20rnr
bigh20rnr's Avatar
1987 YJ Wrangler
Hey Max,
Looks good!
Rick
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub
"Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!!
bigh20rnr is offline
post #10 of 29 Old 10-05-2009, 10:36 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Actually, the YJ threaded holes are not on the sides, but they're on the top and they use the bumper bolt (like I used) and another bolt farther back. The TJ uses holes closer together like the hooks I used. That's why most tow hooks for YJ & TJ applications have 3 holes.
Original Replacement Parts 11236.02 - Tow Hook with Clip in Black for 76-95 Jeep® CJ & Wrangler YJ - Quadratec
http://www.quadratec.com/Assets/Installation/736.pdf
But those are more expensive (okay, only by a dollar) plus there's shipping involved, and most of them are rated at 5,000 lbs.
I just did mine this way for a few reasons:
1) It was cheap
2) It was convenient
3) They're rated at 10,000 lbs. each
4) I like the appearance of not having an un-used hole in the "direct-fit" hooks
I figured that as long as I was wrenching on the heep, I might as well snap a few pics & do a short write-up. My hope is that someone else will get the motivation to add some recovery points to their Jeep, if they currently don't have any.
Not to mention the most important reason, I'm an attention whore.
Max
Mean Max is offline
post #11 of 29 Old 10-05-2009, 10:45 AM
jgillespie
and they even have your name on the side of them man! maxload 10000
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #12 of 29 Old 10-05-2009, 10:50 AM
jbolty
jbolty's Avatar
[/CENTER]
1) It was cheap
Max
Right, on top sharing the bumper bolt and another on further back.
Keep up the good work. I always forget to take pictures til 3/4 of the way thru most projects.
jbolty is offline
post #13 of 29 Old 10-05-2009, 11:06 AM
Sambox
The question I have is how you got the factory Torx fasteners off in the first place!
"Jeeps are the equivalent of barbies for men."-JaikYJ
1996 Cherokee XJ, All stock except for a Flow Master exhaust.........for now. He He.
Sambox is offline
post #14 of 29 Old 10-05-2009, 12:57 PM
SeanMo
Good job. I also like your Jeep's black eyes. Cool
'94 YJ, 2.5" lift on 32's
SeanMo is offline
post #15 of 29 Old 10-05-2009, 01:19 PM
rustywrangler
Torx bits, Weld on a nut, grind off two flat sides to get a wrench on it among other options.
Best place to attach recovery hook...other newb questions jp575 TJ Wrangler Technical Forum 12 04-18-2009 06:29 PM
tj front hook installation rc_007 TJ Wrangler Technical Forum 2 12-25-2008 07:26 PM
Stock rear recovery hook question MCDavis TJ Wrangler Technical Forum 2 12-09-2008 08:43 AM
Rear Tow Hook installation breckboarder55 TJ Wrangler Technical Forum 8 02-27-2008 12:30 PM
recovery hook help ImSuck TJ Wrangler Technical Forum 5 04-09-2006 01:53 PM
