Total newbie, bought first jeep Feb 2013. 1990 YJ - Page 6 - JeepForum.com
post #76 of 209 Old 02-13-2013, 07:18 AM
pete1991YJ
Originally Posted by vdubbles24 View Post
What vehicle the 8.8 common in? Is it a swap you could complete on a Sunday?
Depends. If you have a welder, some cutting and grinding ability, all the parts lined up, and experience. Or could just buy one ready made from East Coast Gear Supply (ECGS) which was in those links I gave earlier.
Realistically, Most guys buy the Ford rear from a junkyard and spend time getting it ready, perhaps new bearings or gears, etc. before they try to put it in. New brakes and some kind of locker perhaps is a good idea. Having it all ready first is definitely easier. Then the actual swapping is only a (long) saturday or something. Its the prep work that takes time.
There *are* kits for this swap which make it a lot easier, which include spring and shock mounts, driveshaft adapters, etc. RuffStuff is one of the better-known ones.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #77 of 209 Old 02-13-2013, 10:44 AM Thread Starter
vdubbles24
So what tired if I got new ones would be appropriate? I don't want to look odd or outta place.
Thanks
Brandon
vdubbles24 is offline
post #78 of 209 Old 02-13-2013, 12:00 PM
pete1991YJ
Tires, you mean? Well, on stock (ish) axles and moderate lift I would stick with 31's or 33's. Mine has 31" BFGoodrich AT's but then again I don't do mud. Mine mostly does DD with some snow up to 2-3 ft deep. I do go on the NY Thruway weekly and it is able to use 5th gear and get 20 MPG's.
Other guys like mud-terrain tires and they obviously go in the mud - but not real good in snow.. Still other guys like super swampers. Or the hardcore rock-crawling set likes goodyear MT/R's. It all just really depends on how you plan to drive it, and what you forsee driving thru.
EDIT: WAIT A MINUTE HERE -- YOU'RE ALREADY ON 37's what kind of axles are under there right now? Trailworthy Fab has a screaming good deal on used military surplus Goodyears in 37x12.5.
post #79 of 209 Old 02-13-2013, 03:56 PM Thread Starter
vdubbles24
Lil mud here and there. Nothin serious. Snow of course. From what I've gathered axles are stock. Lookin into gears and tires. I've been told 37s make axles a ticking time bomb.
post #80 of 209 Old 02-13-2013, 05:34 PM
pete1991YJ
Wow. I'm amazed they are still alive instead of becoming little piles of gear teeth. What you have been told is absolutely correct however. At least with stock axles. They really can't handle much tire size, and what you have is into competition territory, size-wise.
At the very least I would get the ford 8.8 rear with alloy axle shafts all around, then it'll live for a while with 37's on there.
Trail Worthy Fab has a screaming good deal on surplus military 37's, usually with more than 70%tread, from the middle east. They take them off humvees.
post #81 of 209 Old 02-14-2013, 08:31 AM Thread Starter
vdubbles24
Talked to local shop today, gettin info on built Dana 44 for rear and have the Dana 30 beefed up. Air lockers and all the goodies around $3G
post #82 of 209 Old 02-14-2013, 08:43 AM
pete1991YJ
$3k is not bad - I'd call it fair. Hope you know them really well and trust them before laying out that kind of $$ tho. A decent D44 can go at least $2k all by itself, for a brand-new one. Let alone air lockers, getting ARB's for that price is a steal.
post #83 of 209 Old 02-14-2013, 09:38 AM
giggityjeeper
a good price....
find an 8.8 and do some research, its not a hard swap and as good as a D44, some say stronger.... anyhow this can be done for under a grand, maybe a bit more if u want it locked....
dana30.... **** order the chromos online, slide them in.... and thats...beefed up... for a 30... lol
all and all tho..... 3G is a good price..... almost sounds like to good to be true scenario to me.... especially for shop to do it..... be that in parts.....anyhow... just saying u could do it yourself with an 8.8 and some parts online, beef the 8.8 up more with a super 88 kit, ...anyhow
...... EDIT....as I read back... you have 37s????
dont run 37 on a 30... beefed up or not it will leave u broke somewhere
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #84 of 209 Old 02-14-2013, 01:14 PM Thread Starter
vdubbles24
I was lookin at parts at rustys the "beefy" kits with air lockers, gears and all was around $2700 he said $600-$800 labor but assured me he can beat it keep it $3g or less the 44 is his axle he built for his jeep but he said change of plans. We shall see.
post #85 of 209 Old 02-14-2013, 01:16 PM Thread Starter
vdubbles24
I thought it sounded to good.......
All my 4x4 buddies use him so that's what I'm goin on.
post #86 of 209 Old 02-14-2013, 01:48 PM
pete1991YJ
Hope it works out for ya cuz that's a freakin sweet deal... he's probably counting on getting a dealer discount or something.
post #87 of 209 Old 02-14-2013, 05:28 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
here you go. useful 8.8 information
http://www.wranglerforum.com/f5/are-...wap-92569.html
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #88 of 209 Old 02-16-2013, 12:37 AM Thread Starter
vdubbles24
I'm ditching 37s go inning smaller with new gears for now. Yet to hear back about Dana deal so.....
Now this night be silly question but oh well.
What are some good replacement seat belts for stock ones. The ones in jeep seem to short and very uncomfortable.
Thanks
Brandon
post #89 of 209 Old 02-16-2013, 08:06 PM Thread Starter
vdubbles24
Got the MC 2100 mounted and adjusted. WOW what a difference. It's like a new jeep. Put about 100 miles on test run with new carb! Ordered some more parts earlier, getting all new exhaust come Tuesday. Ole YJ is starting to come together.
Is there anyone that makes aftermarket vents for the dash I have a few missing. Lol
Thanks again everyone
Brandon
post #90 of 209 Old 02-16-2013, 08:11 PM
pete1991YJ
Dunno about the seatbelts or the vents. Glad to hear its starting to work out tho I still think you shoyuld investigate at least a ford 8.8 rear tho considering everything else... even if you go down to 35's you'll still need it.
BTW if you need stock replacement parts check out www.daveysjeeps.com. All he does is part out wranglers, he does mail-order for small items. He might have the seatbelts and vents for cheap, in fact I'm sure he would.
