Torx sockets - JeepForum.com
post #1 of 21 Old 05-31-2012, 12:07 PM Thread Starter
Travisf90
Torx sockets
So I know there may be a post about this already I looked and had no luck. I need a good set of Torx bits in the socket form I keep stripping or snapping the ones I have if any one has some advice on a good brand it would be great thanks for any advice you guys give
Travisf90 is offline
post #2 of 21 Old 05-31-2012, 12:32 PM
scubamc
I have a set of Craftsman and they have worked pretty good. If you keep stripping or snapping them you might need to use more PB or heat up the bolsts.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 21 Old 05-31-2012, 12:35 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
^This
Even the best set of Torx will get beat up and lose a few battles on a Jeep. Craftsman are nice because they are guaranteed for life, break it? they replace it free. I think the Lowes brand "Husky" and maybe the Home Depot brand has the same type of guarantee. Look into it.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #4 of 21 Old 05-31-2012, 02:52 PM
brentd711
I've started buying NAPA bits that slip into a socket. They are sold in a 2-pack, priced right, hold up better than most I've used and have a lifetime guarantee.
brentd711 is offline
post #5 of 21 Old 05-31-2012, 03:46 PM
crackedcornish
I use S-K's, they also have a lifetime guarantee (and because the shop that carries them is on my route home from work, which is real handy...)
I've had to replace a few that lost battles with the seat belt and roll bar bolts, so I know first hand that they honor that guarantee, without any questions/issues about how long the cheater pipe was or what setting you were using on the impact gun when you broke them.
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #6 of 21 Old 05-31-2012, 03:46 PM
Suprmn
1988 XJ Cherokee
I went to a local retailer (Tool Town) that sells impact torx sockets. The ones I bought were made in Taiwan, but they have held up pretty good and they gave a lifetime warranty so its hard to beat that.
Suprmn is offline
post #7 of 21 Old 05-31-2012, 06:29 PM
1992 renagade
I've found the biggest thing you can do to help stop breaking and stripping torx bits is to give the socket a good whack with a hammer to help seat it in the torx bolt before removing also my 3/8 Snap-on inpact gun helps a ton.
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications
Blue Mountain Jeep Alliance
Delaware jeep Association
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline
post #8 of 21 Old 05-31-2012, 06:46 PM
dillonjm
2013 WK
I like to tap mine too. Makes sure they are seated fully and helps keep from stripping. I've got a set of Craftsman and a set of Huskys and both are about the same.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #9 of 21 Old 05-31-2012, 07:46 PM
jdubsjeep
snap on!!!
jdubsjeep is offline
post #10 of 21 Old 05-31-2012, 07:47 PM
ih1200
Snap On has a set the call heavy duty removal that are very good, Pretty spendy though at over $200 a set
ih1200 is offline
post #11 of 21 Old 05-31-2012, 09:50 PM
SquidsYJ
I got something similar at Advance Auto. It's a set of about a dozen different torx inserts and an adapter for a 3/8" ratchet. I also got an impact driver and mostly use these bits with the impact driver and lots of PB Blaster.
I found out today that if a torx screw is at that point between stripped and rounded out, you can sometimes fit an allen bit into it and still get it off. I believe that the larger T50 bolts will use a 3/8" allen wrench after the star shape has been stripped. Anyways, it's worth a try before you start drilling for an easy out.
SquidsYJ is offline
post #12 of 21 Old 05-31-2012, 10:26 PM
Michaelgoesrawr
Originally Posted by Luuca
^This
Lowes is Kobalt. Home Depot is Husky. And Kobalt will always be greater than Husky lol. They have a warranty similar to craftsman too.
My Kobalt set has held up very well.
Originally Posted by jdubsjeep
snap on!!!
I could've swore snap on makes craftsman or craftsman makes snap on. But either way I'd choose craftsman for price and easy of exchange being there are sears everywhere.
Michaelgoesrawr is offline
post #13 of 21 Old 06-01-2012, 04:14 AM
StruggleBuggy
Drills & Extractors
I had 2-3 Craftsman lose the battle in the last couple of weeks. That was after the PB didn't work, heads stripped, didn't budge. I picked up a set of Gear Wrench security Tork at Advance Auto that has held up pretty well (Sucked that I had to buy the whole set to get one socket to just to remove the Front Roll Bar)
StruggleBuggy is offline
post #14 of 21 Old 06-01-2012, 04:25 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The best torx set you can get is sometimes not goin to get the bolt out without stripping one now and again. Once you get the bolt out, opt for a hex head replacement when you can unlike places like door mounts that may require a direct replacement. I have found that cone washers are immensely helpful when replacing tapered torx bolts with hex head bolts.
Anticanman is offline
post #15 of 21 Old 06-02-2012, 11:46 PM Thread Starter
Travisf90
Home depot sells the hex bolts to replace the Torx I got 16 stainless steel hex that I can screw right it looks much nicer and I kno I may have a chance to get the out
What range of Torx sockets do I need? Headrope Wrangler General Discussion 14 05-19-2010 01:42 PM
Torx bits/sockets set 2jhanna TJ Wrangler Technical Forum 2 03-24-2008 08:22 AM
Torx Sockets The Big H TJ Wrangler Technical Forum 21 06-28-2007 09:40 AM
Torx Sockets? bruker TJ Wrangler Technical Forum 21 01-07-2007 10:21 AM
torx head sockets BassPlaya799 TJ Wrangler Technical Forum 17 03-27-2004 10:58 AM
