*&$%^ Torx Bolts HELP!! - JeepForum.com
post #1 of 31 Old 01-12-2009, 12:31 PM Thread Starter
HanksRide
Purchased these http://www.quadratec.com/products/12010_72.htm mirror movers and can't seem to get the windshield mounting bolts out. 3 out of 4 are just turning, and 1 won't budge. I have busted 1 torx bit already. Do these bolts have nuts on the inside and if so how do you access them?? Let me guess, take the dash out When the 3 that are turning first broke loose they made a poping sound, I bet that was the weld on the inside nut breaking loose. I have turned them about 3 or 4 rounds but they don't seem to be screwing out any or getting any looser.
HanksRide
(Hank is Yellow Lab) He loves it!!
95yj 4.0L, 4" RC Lift, 8.8, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch
HanksRide is offline
post #2 of 31 Old 01-12-2009, 12:39 PM
Douglas S.
Unfortunately, there are captive nuts in behind
1991 Land Cruiser HDJ81
Douglas S. is offline
post #3 of 31 Old 01-12-2009, 12:40 PM
nicehose
you guessed it...dash..nut on back ... and even with dash back its no cake walk , gets tight up under windshield.........only thing EZ to install on my jeep so far has been the GPS garmin..but im waiting for it to somehow break my glass or some other unforseen disaster.....but i still love not like love my jeep
nicehose is offline
post #4 of 31 Old 01-12-2009, 02:22 PM
Bridges31
1987 YJ Wrangler
For the outer bolts, if you have a torch (like a propane torch), just heat up the bolts for like 10 seconds then spray it with some PB Blaster and they should come right out. I did that to a parts jeep I had that had been sitting for years and it the bolts came right out.
You can do the same with the inside bolts, but be very careful so you don't light anything on fire
Bridges31 is offline
post #5 of 31 Old 01-12-2009, 02:26 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
It's a sucky job..
But... Reach up behind the dash, find the nuts and peel off all the spray on insulation/rtv crap they put on at the factory. Then work a wrench up there.
Takes a while but is do-able.
- Ernie
Richmond88yj is offline
post #6 of 31 Old 01-12-2009, 02:26 PM
kloppk
The windshield bolts were assembled using Red Locktite.
You need to heat them up with a torch (as mentioned above) to soften the Locktite before trying to get them out.
kloppk is offline
post #7 of 31 Old 01-12-2009, 02:47 PM
firefighter315
See my post in your other thread about these mounts..... The top bolts are in captive nuts and the bottoms have 1/2 nuts you can reach with a little effort. Mine made that popping sound too. I got lucky and didn't have any of the insulating crap on them that most mention here on JF.....
My YJ Build Thread
firefighter315 is offline
post #8 of 31 Old 01-12-2009, 02:48 PM
the_mork
I'll be messing around with this when I install some light mounts, any tips to heating them up without ruining the paint or is it pretty safe?
the_mork is offline
post #9 of 31 Old 01-12-2009, 02:56 PM
ChasY
I just get the right size drill bit so that when drilling, the head falls off at a certain point. Then a punch through the hole knocks out that sealer stuff and the old nut. With a good drill bit this is pretty quick.
91 YJ 350-sbc/th350/np231 RC 4inch, 1inch homebrew boomerangs, 35 MTRs, D30/8.8=4.10s, tj flares.
00 VW Jetta TDI 45mpg
ChasY is offline
post #10 of 31 Old 01-12-2009, 03:07 PM
jbolty
jbolty's Avatar
Don't do like I did and accidently pass a mapp torch over the glass. But at least the new windshield is clean and free of pits.
jbolty is offline
post #11 of 31 Old 01-12-2009, 03:08 PM
Bridges31
1987 YJ Wrangler
When I took the windshield frame off of my parts jeep that I had, it did bubble up the paint a little bit, but I didn't really care about that so I held the torch to it a little longer than most would. If you hold the flame for about 5-10 seconds and try and angle it away from the paint/glass, you should be okay.
No guarantees though. I would be very very careful about it.
post #12 of 31 Old 01-12-2009, 03:11 PM
rrisher
1987 YJ Wrangler
Just be careful on it heats up and you notice it, it's too late. you've gotten to the point of no return and your paint's ruined!
rrisher is offline
post #13 of 31 Old 01-12-2009, 04:24 PM Thread Starter
HanksRide
What did you do about the new bolts to install, put nuts on the back or tap the hole with threads (if that is even possible) I have never been into one yet.
HanksRide
post #14 of 31 Old 01-12-2009, 04:45 PM
lckdrgn
sodering iron?
If it is just heat how about using a soldering iron directly on the screw? I have a Krago rack on order. I hoped it would be an easy install. Now I'm alittle worried. Bought a 94 with great paint; always inside. Hope this screw come out.
lckdrgn is offline
post #15 of 31 Old 01-12-2009, 05:27 PM
the_mork
Well when the time comes I'll just do it, the passenger side of the windshield frame wont last much longer, It has a rust hole you can stick your fist into and there isn't enough metal left to sand it down so if I mess it up I'm not going to cry.
Oh the wonders of buying a Jeep that lived in Hawaii, the underside is still shiny but the windshield frame and tie downs are rusting right out.
the_mork is offline
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
where can i get torx bolts? yjJeff YJ Wrangler Technical Forum 21 03-01-2009 01:27 AM
Torx Bolts Beach Boy TJ Wrangler Technical Forum 10 09-24-2005 08:30 PM
Torx bolts YoungJeeper YJ Wrangler Technical Forum 4 03-04-2004 09:58 PM
