Torx bolts - JeepForum.com
post #1 of 14 Old 10-01-2008, 10:54 PM Thread Starter
Checo18
Torx bolts
Anyone know any good ways to get out stripped torx bolts
_______ Only in a YJ
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
2.5L, 4" RE lift, 1" booms on the front, Revolvers on the back, 1" B.L., Aussie in the 35, 31" Trxus tires, Gen-rite rocker guards, BTF tube fenders, Pro Comp bumpers, KC lights, Hi-lift and a whole lot of love.
Checo18 is offline
post #2 of 14 Old 10-01-2008, 11:00 PM
Brandon_YJ
1987 YJ Wrangler
There's several ways really.
* If you have a welder, just tack a nut onto the head of it.
* If you have a grinder, then grind a slot into it and use a flat head screwdriver.
* Can you get a set of vice-grips on the head of the bolt?
I'm sure there are a couple more tricks, besides drilling them out, but can't think of any right now.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #3 of 14 Old 10-01-2008, 11:01 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Get a tube of valve grinding compound (paste) and fill the head of the Torx fastener completely full. Gently tap Torx driver into the head of the fastener until it is completely "bottomed out" and then remove the bolt normally. This works on all stripped allen head & Torx head fasteners, unless they are severely mutilated.
Grandpa always said, "Work smart, not hard!"
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 14 Old 10-01-2008, 11:04 PM
Contra
i use my Dremel to cut the thing off
when my friends get into that situation
because i don't
Ever Gone Geocaching?
Contra is offline
post #5 of 14 Old 10-02-2008, 11:13 AM
RikRotorhead
One more trick is to use a dremmel and cut the sides off of two sides, and use an open end wrench on it.
Anytime I have to take a torx bolt out, I use an impact driver on it. I bought a pretty nice one from Harbor Friegnt Tools. It's the kind you hit with a hammer as you are turning it. Work's like a champ every time. I don't want to take a chance on stripping those stoooopid bolts out.
Get a can of PB and spray it for a couple days too.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #6 of 14 Old 10-02-2008, 11:16 AM
rrisher
1987 YJ Wrangler
Do you have to let the stuff set and dry first? If so, how long...?
rrisher is offline
post #7 of 14 Old 10-02-2008, 11:35 AM
Burnerman
Burnerman's Avatar
I doubt it. Sounds like a great idea. It'll give the bit "bite" so it doesn't spin out and strip.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #8 of 14 Old 10-02-2008, 01:20 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
No, it doesn't "dry" as it's not an adhesive. It's just a lubricating paste with "grit" in it. The solid grit material takes up the slop & prevents slippage of the driver. Fill in the head of the fastener, then remove it, no waiting.
Mean Max is offline
post #9 of 14 Old 10-02-2008, 08:15 PM
rrisher
1987 YJ Wrangler
That bit of information could have come in handy a few days ago...
rrisher is offline
post #10 of 14 Old 10-02-2008, 08:44 PM
pacodelahoya
1987 YJ Wrangler
This is sort of on topic, a buddy told me the other day, and I used this trick to get the spring perch studs out of a dana 60 from a late seventies dodge.
Heat up the stuck fastener, as hot as you can, then hold a candle to it where the threads go into whatever. The wax chases the threads like flux. I'll tell you, if the studs weren't so hot, I think I could have gotten em out with my fingers.
'80 CJ 5 w/360
87 Wangler build in progress 350, 350, np205, 5.38 gears, soa,d60/14 bolt,accepting donations for wheels and tires(just kidding)
2000 Grand Cherokee LTD w/4.7
Do they have AA for Jeeps?
pacodelahoya is offline
post #11 of 14 Old 10-02-2008, 09:06 PM
whitie_08
drill a hole beside it and use a different bolt. i had to on the seat belt where it mounts to the floor.
it is safe though, i used the provided floor supports.
whitie_08 is offline
post #12 of 14 Old 10-02-2008, 09:16 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Just think how easy it'll be next time!
Mean Max is offline
post #13 of 14 Old 10-03-2008, 12:31 AM Thread Starter
Checo18
Next time I just hope the damn things don't strip
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
Checo18 is offline
post #14 of 14 Old 10-03-2008, 05:31 AM
RobsYJeep
wow I had never heard of that one.. I'll have to try it!
cheers
Rob
RobsYJeep is offline
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
*&$%^ Torx Bolts HELP!! HanksRide YJ Wrangler Technical Forum 30 01-16-2009 02:42 PM
Torx Bolts Beach Boy TJ Wrangler Technical Forum 10 09-24-2005 08:30 PM
Torx bolts YoungJeeper YJ Wrangler Technical Forum 4 03-04-2004 09:58 PM
