Torx bolts - JeepForum.com
post #1 of 18 Old 07-26-2010, 06:09 PM Thread Starter
Firedad
Torx bolts
Ok, I know some folks will think I'm nuts, but we've recently taken about all the torx bolts off the YJ to do a proper paint job (under the hinges, etc.). Now, about 75% of the bolts came out nicely (if you consider PB, heat, and an impact gun nicely). But 25% got screwed up. Any ideas where I can buy some to replace the missing ones? I believe they are 5/16"x18 thread.
Also, when I replace them, should I use anti-seize or thread lock? I don't anticipating taking them apart soon, but I certainly want to keep rust and paint from working their way into the threads.
Firedad is offline
post #2 of 18 Old 07-26-2010, 06:15 PM
GRYDE001
Fastenal (sp?) stores should have all the bolts you need. Consider getting regular bolt heads or allen heads for replacements. I use anti-sieze on every bolt I remove from mine, as long as it's not something that REQUIRES threadlock, I hate the stuff.
""Leave it stock, it will live longer. Just understand that its never gonna be as fast as a minivan""
GRYDE001 is offline
post #3 of 18 Old 07-26-2010, 06:15 PM
ShowStopper
Great post, I'm in the process of doing the same thing.... I'm anticipating plenty of screwed up bolts.
ShowStopper is offline
post #4 of 18 Old 07-26-2010, 06:18 PM
jeepnaked89
i wouldn't but here you go Machine screws, Torx pan head thread cutting screw type F, Zinc plated steel (waxed)
Originally Posted by molshove View Post
"I'll disregard the second half of your post with the understanding that this kind of **** flies in the YJ forum, cluttered with 16 year olds and infantile adults with no future - but we don't support it here."
jeepnaked89 is offline
post #5 of 18 Old 07-26-2010, 06:19 PM
Tcarsten
Deffinetly use a different head i used the allen heads on mine.
The ****ty thing was i had to buy 100 of them it was cheaper them buying 1 at a time. And now i have a whole bunch as replacments
Tcarsten is offline
post #6 of 18 Old 07-26-2010, 08:25 PM Thread Starter
Firedad
"And now i have a whole bunch as replacments"
Wanna sell some ???
Firedad is offline
post #7 of 18 Old 07-26-2010, 09:25 PM
87jeepyj
1987 YJ Wrangler
i got all mine right off of 4wd.com
87jeepyj is offline
post #8 of 18 Old 07-26-2010, 09:47 PM
bscline09
I would suggest using allen heads because the regular bolts (ie phillips head or flat blade...not sure proper name) dont allow enough leverage so you can tighten them, unless tightened with a drill which can be a pain to get out every time. With allen wrench heads, you have the leverage with the wrench and a heck of a lot easier than moving that drill around everytime. Torx heads suck and have had many broken! Dont replace with those IMO
bscline09 is offline
post #9 of 18 Old 07-26-2010, 09:49 PM
87jeepyj
1987 YJ Wrangler
yea the ones i bought came with allen heads
87jeepyj is offline
post #10 of 18 Old 07-27-2010, 05:38 PM
Tcarsten
Wanna sell some ???
Yea that would be cool
Im not sure how we could do this
How many do u need
Tcarsten is offline
post #11 of 18 Old 07-27-2010, 05:49 PM
CrzyMtnMan
In this application, I never re-use any fastner. Find a local fastner supplier, although I have never used Fastenal they should be able to help you out, as bulk fastners are not that expensive, replace all with new when you re-assemble. They should be able to supply you with the tool or bit to do so.
CrzyMtnMan is offline
post #12 of 18 Old 07-27-2010, 08:00 PM
brapwithit
Yup they are 5/16x18x1" or 1-1/4". I just bought a box of 100 stainless for about 40 bux. We sell them at work. They are call flat socket cap. Or flat socket head. Fastenal should have them.
brapwithit is offline
post #13 of 18 Old 07-27-2010, 11:20 PM
pmedic271
I had a body shop replaced the windshield frame on my YJ and they broke 4 of the bolts and could not replace them - needless to say how ticked off I was - I searched hardware, stores body shop suppliers, etc and finally found them on ebay.
pmedic271 is offline
post #14 of 18 Old 07-28-2010, 06:15 PM Thread Starter
Firedad
I found them on 4wd.com for $1.25 for black and $1.50 for stainless (each). There's a Fastenal about 5 miles away, so I might give them a shout. I just hate the thought of using old, rusty bolts when I've gone this far to do a decent job. Thanks everyone for their ideas / help. I'll let you know what I find out from them.
Firedad is offline
post #15 of 18 Old 07-29-2010, 01:54 AM
nucleardave
1987 YJ Wrangler
quadratec sells complete bold replacement kits. for every bolt there could possibly be on your jeep. i was looking into getting a kit when i was contemplating a frame swap. they offer torx head and regular hex head. I dont know how much you're looking to spend, and this kit is probably WAY overkill, but a stainless torx replacement kit ran about $200. the hex head set was cheaper than that but i dont know how much off the top of my head. again - thats for everything on your jeep. so you'll get way more than you need...
never hurts to have backups.
nucleardave is offline
bolts , torx
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
where can i get torx bolts? yjJeff YJ Wrangler Technical Forum 21 03-01-2009 01:27 AM
*&$%^ Torx Bolts HELP!! HanksRide YJ Wrangler Technical Forum 30 01-16-2009 02:42 PM
Torx Bolts jeepinlv TJ Wrangler Technical Forum 8 12-06-2004 10:11 AM
#40 TORX Bolts... NIUPonyBoy YJ Wrangler Technical Forum 9 10-05-2004 07:28 AM
