Quantcast Torque Specs for head bolts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Torque Specs for head bolts
Old 07-16-2008, 05:12 PM   #1
doeboy99
doeboy99's Avatar
1979 CJ7
Does anyone know the torque spec for the head bolts on a 89 wrangler with a 4 banger in it.
doeboy99 is offline   Reply With Quote
Old 07-16-2008, 05:55 PM   #2
doeboy99
doeboy99's Avatar
1979 CJ7
bump!!!!!!!!!!!!!!!!!
Old 07-16-2008, 06:00 PM   #3
NJeepyj91
I recently did one of these. I hated it. I had to refer to the sequence multiple times.
You have to make alignment dowels from the old head bolts.
From front to back from drivers side:
8 4 1 5 9
rear of motor. Sequence
7 3 2 6 10
The dowels go in 7 and 10.
Install composite gasket without sealant.
Use loktite on bolt 8.
Install all head bolt (xcept 7&10) Once you have threaded the other bolts, hand thread 7 and 10. You have located the gasket on the cylinder head.
Tighten bolt 1 to 10 to 22 foot pounds using the above sequence (I wish I had a scanner!)
Using the same sequence, tighten to 45 foot pounds.
Tighten 1 through 7 to 110 foot pounds then tighten bolt 8 to 100 foot pounds. Lastly,
tighten bolts 9 and 10 to 110 foot pounds.
Please be sure to use NEW headbolts.
She's going to bury me in this thing.
91 4.0 stick. Posi Lok, Borla, 31s on steelies, Dem Bonz Shackles and lots of other junk on my junk.
NJeepyj91 is offline   Reply With Quote
Old 07-16-2008, 06:02 PM   #4
idaholtby
Step1 22ft lbs
Step2 45ft lbs
Step3 Bolts 1-6 110ft lbs
Step4 Bolt 7 100ft lbs
Step5 Bolts 8-10 110ft lbs
Bolt Pattern
8 4 1 5 9
Front Rear
7 3 2 6 10
Info pulled from Chilton Manual for '89 2.5L
idaholtby is offline   Reply With Quote
Old 07-16-2008, 06:12 PM   #5
NJeepyj91
Pulled from Mitchell. We posted about the same time.
Old 07-17-2008, 08:35 AM   #6
doeboy99
doeboy99's Avatar
1979 CJ7
Thanks To all Runs Great No Leaks
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
