torque spec - JeepForum.com
post #1 of 2 Old 12-21-2011, 10:55 AM Thread Starter
oleyjman
1993 WJ
torque spec
I have 1993 jeep wrangler 2.5. I'm having to replace a rocker arm. Can someone tell me the torque setting for the nut on top. thanks.
oleyjman
oleyjman is offline
post #2 of 2 Old 12-21-2011, 11:29 AM
tdewit
Copied from the 1993 2.5 FSM:
TORQUE SPECIFICATIONS
TORQUE SPECIFICATIONS TABLE
Application Ft. Lbs. (N.m)
Camshaft Sprocket Bolt .......................... 80 (108)
Connecting Rod Cap Nuts .......................... 33 (45)
Cylinder Head Bolts (1)
Stage 1 ........................................ 22 (30)
Stage 2 ........................................ 45 (61)
Stage 3 .................................. (2) 110 (149)
Drive Plate-To-Converter Bolts ................... 40 (54)
Exhaust Manifold Bolts (3)
Bolt No. 1 ..................................... 30 (41)
Bolt No. 2-5 ................................... 23 (31)
Nut No. 6 & 7 .................................. 30 (41)
Fan Bolts ........................................ 18 (24)
Flexplate-To-Crankshaft Bolts ................ (4) 50 (68)
Flywheel-To-Crankshaft Bolts ................. (4) 50 (68)
Intake Manifold Bolts (3)
Main Bearing Cap Bolts
Stage 1 ....................................... 40 (54)
Stage 2 ....................................... 70 (95)
Stage 3 ...................................... 80 (108)
Oil Pump Retaining Bolts
Long ........................................... 17 (23)
Short .......................................... 10 (14)
Oxygen (O2) Sensor ............................... 23 (31)
Pulley-To-Vibration Damper Bolts ................. 20 (27)
Rocker Arm Bolts ................................. 21 (28)
Starter Bolts .................................... 33 (45)
Throttle Body-To-Intake Bolts .................... 10 (14)
Vibration Damper Bolt ....................... (5) 80 (108)
Water Pump Bolts ................................. 25 (34)
INCH Lbs. (N.m)
Front Cover-To-Block Bolts ........................ 62 (7)
Oil Pan Bolts
1/4" X 20 ..................................... 114 (13)
5/16" X 18 .................................... 156 (18)
Oil Pump Cover Bolts .............................. 70 (8)
Valve Cover Bolts ................................. 85 (9)
(1) - Tighten in sequence. See Fig. 3.
(2) - All except bolt No. 7. Tighten bolt No. 7 to
100 ft. lbs. (136 N.m).
(3) - Tighten bolts in sequence. See Fig. 2.
(4) - Tighten to specification and an additional 60 degrees.
(5) - With bolt cleaned and threads lubricated with oil.
ENGINE SPECIFICATIONS
GENERAL ENGINE SPECIFICATIONS
GENERAL ENGINE SPECIFICATIONS TABLE
Application Specification
Displacement .......................... 150 Cu. In. (2.5L)
Bore ..................................... 3.88" (98.5 mm)
Stroke ................................... 3.19" (81.0 mm)
Compression Ratio
Cherokee ......................................... 9.2:1
Wrangler ......................................... 9.1:1
Fuel System .......................................... PFI
Horsepower @ RPM
Cherokee .................................... 130 @ 5250
Wrangler .................................... 123 @ 5250
Torque Ft. Lbs. @ RPM
Cherokee .................................... 149 @ 3000
Wrangler .................................... 139 @ 3250
CRANKSHAFT, MAIN & CONNECTING ROD BEARINGS SPECS
CRANKSHAFT, MAIN & CONNECTING ROD BEARINGS SPECS TABLE
Application In. (mm)
Crankshaft
End Play ....................... .0015-.0065 (.038-.165)
Runout ............................................. (1)
Main Bearings
Journal Diameter ......... 2.4996-2.5001 (63.490-63.503)
Journal Out-Of-Round ...................... .0005 (.013)
Journal Taper ............................. .0005 (.013)
Oil Clearance .................. .0010-.0025 (.025-.063)
Connecting Rod Bearings
Journal Diameter ......... 2.0934-2.0955 (53.172-53.226)
Oil Clearance .................. .0015-.0025 (.038-.063)
(1) - Information not available from manufacturer.
CONNECTING RODS SPECIFICATIONS
CONNECTING RODS SPECIFICATIONS TABLE
Bore Diameter
Pin Bore ................... .9288-.9298 (23.591-23.617)
Crankpin Bore ............ 2.2080-2.2085 (56.083-56.096)
Center-To-Center Length ...... 6.123-6.127 (155.52-155.63)
Maximum Bend .................................. .003 (.08)
Maximum Twist ................................. .006 (.15)
Side Play ............................ .010-.019 (.25-.48)
PISTONS, PINS & RINGS SPECIFICATIONS
PISTONS, PINS & RINGS SPECIFICATIONS TABLE
Piston
Clearance ...................... .0013-.0021 (.033-.053)
Diameter ........................................... (1)
Pins
Diameter ................... .9306-.9307 (23.637-23.640)
Piston Fit ..................... .0003-.0007 (.007-.018)
Rod Fit ...................................... Press Fit
Rings
No. 1 & 2
End Gap .......................... .010-.020 (.25-.51)
Side Clearance ............... .0017-.0032 (.043-.081)
No. 3 (Oil)
End Gap ......................... .015-.055 (.38-1.40)
Side Clearance .................... .001.010 (.03-.24)
(1) - Information is not available from manufacturer.
Replace pistons if piston clearance exceeds
.004" (.10 mm).
CYLINDER BLOCK SPECIFICATIONS
CYLINDER BLOCK SPECIFICATIONS TABLE
Cylinder Bore
Standard Diameter ............ 3.875-3.877 (98.42-98.48)
Maximum Taper ............................... .001 (.03)
Maximum Out-Of-Round ........................ .001 (.03)
Minimum Deck Height ....................... 9.320 (236.73)
Maximum Deck Warpage .......................... .008 (.20)
VALVES & VALVE SPRINGS SPECIFICATIONS
VALVES & VALVE SPRINGS SPECIFICATIONS TABLE
Intake Valves
Face Angle ......................................... 45
Head Diameter .......................... 1.90" (48.3 mm)
Minimum Margin .......................... .031" (.79 mm)
Minimum Refinish Length ............. 4.889" (124.18 mm)
Stem Diameter ................ .311-.312" (7.89-7.92 mm)
Valve Tip Maximum Refinish .............. .010" (.25 mm)
Exhaust Valves
Head Diameter .......................... 1.50" (38.1 mm)
Minimum Refinish Length ............. 4.927" (125.15 mm)
Stem Diameter ................ .311-.312" (7.90-7.92 mm)
Valve Springs
Free Length ............................... 2.0" (51 mm)
Installed Height ................................... (1)
Out-Of-Square ...................................... (1)
Pressure (2)
Valve Closed ......... 80-90 @ 1.64 (36.3-40.8 @ 40.8)
Valve Open ................. 200 @ 1.216 (90.7 @ 30.9)
(2) - Lbs. @ In. (kg @ mm).
CYLINDER HEAD SPECIFICATIONS
CYLINDER HEAD SPECIFICATIONS TABLE
Cylinder Head Height ................................. (1)
Maximum Warpage ........................... .008" (.20 mm)
Valve Seats
Intake Valve
Seat Angle .................................. 44.5-45
Seat Width ................. .040-.060" (1.02-1.52 mm)
Maximum Seat Runout ................. .0025" (.063 mm)
Exhaust Valve
Seat Bore Diameter ............................... (1)
Valve Guides
Intake Valve
Valve Guide I.D. ........... .313-.314" (7.95-7.98 mm)
Valve Stem-To-Guide
Oil Clearance ............... .001-.003" (.03-.08 mm)
Exhaust Valve
Valve Stem-To-Guide
CAMSHAFT SPECIFICATIONS
CAMSHAFT SPECIFICATIONS TABLE
Bore Diameter ........................................ (1)
End Play ....................................... (2) 0 (0)
Journal Diameter
No. 1 ........................ 2.029-2.030 (51.54-51.56)
No. 2 ........................ 2.019-2.020 (51.28-51.31)
No. 3 ........................ 2.009-2.010 (51.03-51.05)
No. 4 ........................ 1.999-2.000 (50.78-50.80)
Journal Runout ....................................... (3)
Lobe Height .......................................... (1)
Lobe Lift .................................... .265 (6.73)
Oil Clearance ........................ .001-.003 (.03-.08)
(2) - Engine running.
(3) - Information is not available from manufacturer.
Manufacturer specifies .001" (.03 mm) maximum base
circle runout.
VALVE LIFTERS SPECIFICATIONS
VALVE LIFTERS SPECIFICATIONS TABLE
Bore Diameter ................ .9055-.9065 (22.987-23.025)
Lifter Diameter .............. .9040-.9045 (22.962-22.974)
Oil Clearance ........................ .001-.002 (.03-.05)
tdewit is offline
torque spec please Scott00TJ TJ Wrangler Technical Forum 1 04-02-2009 05:17 PM
Torque Spec rjt36 TJ Wrangler Technical Forum 2 01-18-2007 12:12 PM
Torque Spec?? Help?? bondo303 TJ Wrangler Technical Forum 2 06-14-2004 04:05 PM
Torque Spec yru_stuk TJ Wrangler Technical Forum 4 04-08-2003 04:57 PM
torque spec. ukjeeping TJ Wrangler Technical Forum 3 12-27-2002 08:08 PM
