torque on shackles - JeepForum.com
post #1 of 2 Old 10-18-2001, 12:33 PM Thread Starter
zuck2001
torque on shackles
I just bought a daystar 1.25" shackele lift for the front, and a Conferr 1" for te rear. Can someone tell me how much torque i should use on these. I've heard 100, but i want to make sure. Thanks
'89 YJ w/ 4.2L I-6, 2.5" Rancho SL, 2" BL, 1.25" SHKLL, Uniden CB, 2 JL Audio Subs and Banpass box with a 300/1 2 channel Earthquake Amp, 33X12.5 Cooper S/T, no sway or trac bars, no bump stops, 2 titanium KC's.
zuck2001 is offline
post #2 of 2 Old 10-18-2001, 06:03 PM
osburn
osburn's Avatar
The manufacturers specs are always around 100ftlbs. But really, if you want them to work their best, around 30lbs is what you want. Use nylock nuts so they don't come off and it's one of those things you always want to keep an eye on. But if you tighten them to 100lbs they'll be too tight and stiffen your ride and reduce your flex. I just tighten mine up till they're snug. I'd guess it's around 30lbs, but it ain't that crucial. Just get them snug.
Matt Osburn
Score 1032
osburn is offline
Less torque on the shackles? TheNewbie YJ Wrangler Technical Forum 10 05-18-2009 02:30 PM
Torque specs for stock shackles frozennorth YJ Wrangler Technical Forum 1 02-26-2009 09:57 AM
torque specs on more shackles.....what are they jdietz92 Wrangler General Discussion 1 02-01-2009 01:00 AM
RE Greasable Shackles: Torque??? watkins 92 yj YJ Wrangler Technical Forum 3 09-19-2006 08:12 AM
Torque spec for shackles Evilgrin YJ Wrangler Technical Forum 8 11-12-2003 09:20 AM
