torque to crush a sleeve? - JeepForum.com
post #1 of 3 Old 05-01-2013, 11:14 PM Thread Starter
g_oneill
How much torque can you apply to the pinion nut to get the sleeve to start crushing on a D35. Installed new ring and pinion. I am up to 250 lb/ft.
g_oneill is offline
post #2 of 3 Old 05-02-2013, 12:46 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Crush sleeve is a preload-setting device, and the torque varies. It depends on how much crush is needed to properly preload the pinion bearings. Somewhere around 200-210lb-ft, you should have begun tightening your pinion nut in small increments and regularly checking bearing preload - turning force - with a lb-in torque wrench to assess the amount of preload on the bearings.
STOP RIGHT NOW if you don't have an lb-in torque wrench that can be read (beam-type, dial-type. A "micrometer-type" won't work) and go get one - and get a spare sleeve, while you're about it. If the bearing preload is set too high, you must replace the sleeve and reset it! You can't "uncrush" a sleeve.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #3 of 3 Old 05-02-2013, 10:04 AM Thread Starter
g_oneill
5-90 Thanks for the reply. I do have the right torque wrench to test. I was only at 6 in/lbs (Spec says 14-27 for new bearings) at 250 on my big torque wrench on the pinion nut.
I figured it out. I was using a 6inch impact extension on the end of the torque wrench (to reach out past the yolk). Giving me a false reading on the big wrench, I think it was twisting(removed the extension). I am now at 210 ft/lbs and 18-19 in/lbs on the preload. I then put on the yolk seal and a new nut went to 210 again now have 21 on the preload.
I remember cursing the shim process on the D30 and could not wait to get to the crush sleeve. I think I like the shims better.
g_oneill is offline
