Quantcast Torque converter bolt torque misprint! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Torque converter bolt torque misprint!
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 03-16-2009, 09:54 AM   #1
planedog
FYI the Factory service Manual for the '94 Wrangler lists the torque converter bolt torque at 55 ft/lbs. This is WAY more torque than the nuts on the torque converter can stand, it should be more like 30 ft/lbs.
Don't learn this the hard way, like I did.
planedog is offline   Reply With Quote
Old 03-16-2009, 09:58 AM   #2
UltimatE
Resident Audio Guru
UltimatE's Avatar
Were you using old bolts or new bolts?
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Old 03-16-2009, 10:00 AM   #3
TheRealOldjeep
The 3 bolt convertors are 40 ft lbs, the 4 bolt convertors are 55 ft lbs. If you managed to break one, chances are that it wasn't a graded TC bolt, just some junk bolt. Those things are tough.
Chuck P
94 YJ 2.5L/AW4
http://www.jeepforum.com/forum/f22/94-yj-649943/ Build Thread
www.oldjeep.com My site
www.mntrailriders.org My Club
TheRealOldjeep is offline   Reply With Quote
Old 03-16-2009, 10:03 AM   #4
planedog
Yep, that's what the FSM says... Try it and you will pull the threads our of the nuts on the TC.
Old 03-16-2009, 10:11 AM   #5
TheRealOldjeep
I've done it many times which makes me think that you have a bad convertor or the wrong sized bolts if you pulled the threads out with only 55 ft lbs.
Chuck P
94 YJ 2.5L/AW4
http://www.jeepforum.com/forum/showthread.php?t=649943 Build Thread
Old 03-16-2009, 10:24 AM   #6
planedog
Hmmm............ The threads that peeled off the bolts looked great and fit the bolts perfectly, only in the wrong location. It is a NAPA reman converter and I will verify the bolt size possibility when I get it all back out Saturday but doubt it. Ford calls for 30ft/lbs for the same size bolt in an F-150.
Old 03-16-2009, 10:31 AM   #7
TheRealOldjeep
No idea who remanufacturs for NAPA, but you might want to try these guys for a replacement.
http://www.transtar1.com/torque.asp
Transtar and Precision are good rebuilders, if you see anything that says DAACO - run.
Chuck P
94 YJ 2.5L/AW4
Old 03-16-2009, 12:48 PM   #8
planedog
Thanks for the input. I guess I will just be Heli-Coiling the nut plates and torquing to 30 ft/lbs this time. I doubt that I will need a new converter at this point.
Glock Forum
